Will a p28 work with my Turbo GSR?
I'm in the process of getting a Jumper Harness for my 96 GSR, but it's hard to find a USDM p72
I've got lots of friends with stock unchipped p28, would that work with my set-up?
TIA
TIA
Youre going to at least want to have the DOHC program. Try to find someone with a P28 from a Del sol (the B16 one...DOHC). Or get one of those SOHC P28s and send it out to get chipped for DOHC, but make sure to specify its for a turbo application (ie. no advanced timing/funky fuel maps).
Yes it will work and it doesnt matter if its DOHC or SOHC. The only thing you wont have controll over is the secondary runner control that the P72(GSR) has. If you have a skunk2 or JG intake manifold there are no secondary runners, so the p28 will work.
thanks jeff,
But once I get it chipped to DOHC, I've heard that I can' use it because I won't have the ability to use the secondary runners
Are there any ill effects to using this ECU on the b18c1
Matt G (black eg w/Advans and GSR swap) put his Kenji ECU in long before he installed his Skunk2 IM and didnt lose any power by not having the secondaries(dyno proven).
With the secondaries not hooked up they will remain open at all times. You will not lose any power above 5700 because nothing has changed. You will loose hp and torque below 5700 rpm, dyno proven....
Ok,
so once I get my hands on a p28, I need to have it rechipped to DOHC and what else? change the rev limiter? etc etc?
TIA, I hope this will solve my turbo woes....
and how exactly do I leave the secondaries open at all times? Just unhook that vacuum line on the back?
The way the secondaries work.....
The secondaries are always open when the car is off. When you start the car the ecu sends a ground signal to a soleniod which sends vacuum to the diaphram. This closes the butterflies. At 5700rpm the ecu cuts the ground which opens the butterflies. If everything is hooked up like normal and the ecu doesn't send the signal (P28) then they will just stay open. There is no need to disconnect anything. I would keep them functional unless you are going to change to another manifold (skunk or jg). If you want to feel the difference they make you can just unhook the vacuum line to the diaphram and they will stay open. Drive it and see if you feel the difference below 5700.
on the dyno i lost about 3-5 hp midrange with them open at all times, but i gave my diaphram to my buddy with an h23 swap so it could work his runners. thats when i dynoed again and lost the 3-5hp midrange (3500-4200rpm). when i put the skunk2 on i gained 13hp at 6500, and about 5hp midrange. overall it increased the whole powerband. i think the way the stock IM is on the gsr is a pretty shitty design anyway.
We are only talking about a GSR right? Cause I have a 2000 Civic Si and the itake manifolds are VERY different from the B16 to B18 (for the second runners).
I have Hondata 2B, DSM 450's, P28 and an OBD2 to 1 Harness for my setup, NO MORE BLUE BOX!!
