How weak are stock sleeves...Look inside
Old Dec 7, 2002 | 08:17 PM
earl's Avatar
Default How weak are stock sleeves...Look inside
Here is a B18C block that came in for repair today. It had CTR pistons and a milled head. Compression was close to 13-1. It lived less than a month without tuning. Now if this can happen to an N/A block, what could a turbo have done to it??
Old Dec 7, 2002 | 08:22 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How weak are stock sleeves...Look inside (earl)
How come it wasnt tunned?
13:1= lots of tunning and premium gas ALWAYS.
Hope that dude learn'd his lession (to bad he had to learn it the hard way)
Blaze
Old Dec 7, 2002 | 08:42 PM
BoostedED9's Avatar
Default Re: How weak are stock sleeves...Look inside (Blaze45)
Blaze
no it would need race gas all the time.. 93 would not be enough
Old Dec 7, 2002 | 08:44 PM
TheSwift1's Avatar
detonation can destroy ANY block...built or not...
what i would really like to see is a built block with built sleeves destoyed by detonation...anyone have any pics of that?
Old Dec 7, 2002 | 08:46 PM
turbo craig's Avatar
Default Re: How weak are stock sleeves...Look inside (TheSwift1)
it kinda looks like a block guard woulda helped that...atleast a lil while longer till it was tuned
Old Dec 7, 2002 | 09:05 PM
Tofurky's Avatar
Default Re: How weak are stock sleeves...Look inside (turbo craig)
ack. that makes me nervous about 14 psi....
Old Dec 7, 2002 | 09:06 PM
BoostedED9's Avatar
Default Re: How weak are stock sleeves...Look inside (Ruckus138)
fine tunning is hte key to having a good runing motor
Old Dec 7, 2002 | 09:07 PM
2K_TEG's Avatar
earl,
what is up with those ridges? Looks like they are perfectly spaced?
Old Dec 7, 2002 | 09:15 PM
mos's Avatar
mos
Default Re: How weak are stock sleeves...Look inside (2K_TEG)
Looks like the ridges are from the aluminum part of the block that holds the sleeves, not in the sleeves themselves.
Old Dec 7, 2002 | 09:27 PM
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (mos)
Correct, I should have included the broken off piece in the pix also.
Old Dec 7, 2002 | 09:33 PM
2K_TEG's Avatar
ah...the picture is deceiving.
Old Dec 7, 2002 | 09:57 PM
TREVER's Avatar
Default Re: How weak are stock sleeves...Look inside (BoostedED9)
I know a lot of people running 91 on 13-1 no prob tuning is key
Old Dec 7, 2002 | 10:01 PM
bgod's Avatar
Default Re: How weak are stock sleeves...Look inside (TREVER)
know and have met plenty of people running stock sleeved boosted b series motors. plenty of life in them also.
like stated above, any block can blow or break a sleeve such as above. even a fully built, sleeved block. too many factors.
Old Dec 7, 2002 | 10:02 PM
Sonny's Avatar
Got JB Weld?
sonny
Old Dec 7, 2002 | 10:04 PM
trbob16a's Avatar
Default Re: How weak are stock sleeves...Look inside (Sonny)
I agree that:
13:1 is do-able on 93 octane
detonation will kill a built or unbuilt motor
and I'll add that.. the odds of damage like this happening on an all motor car revving to 9500 and making say 200whp are much more likely than a turbo car revving to 8000 making 250whp.
Old Dec 7, 2002 | 10:28 PM
SiRkid's Avatar
Default Re: How weak are stock sleeves...Look inside (trbob16a)
tuning..last time i read...gsr sleeve reportedly help up to 609 boosted whp..(posted by you earl?)
tuning tuning tuning.
thats the one thing im afraid of..is having my car tuned right.
Old Dec 7, 2002 | 11:18 PM
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (SiRkid)
Not me on the 609whp. That's insane. I believe the number but what you don't hear is that the guy sold the motor to his buddy and he blew it up a few months later. It's not what you hear, it's what you don't hear about.
Old Dec 7, 2002 | 11:20 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
AMEN Earl.......sooO true
Old Dec 8, 2002 | 08:00 AM
Quick 200k Mile Motor's Avatar
I agree that:
It is do-able, but it'll have to be severely retarded on the timing.
With high compression comes more heat.
It should be nothing above 12 on comp ratio for 93 octane.
Reason: detonation will creep up after driving around for a while.
That is often skipped for a daily street car.
Old Dec 8, 2002 | 08:31 AM
Optiks.'s Avatar
bahahahaha
Got JB Weld?
sonny
Old Dec 8, 2002 | 10:44 AM
tygsr's Avatar
Default Re: How weak are stock sleeves...Look inside (Optiks)
WEll the thing that decribes it best is " no tuning". I have heard of an seen many boosted b18's run 20+psi and not break a sleeve. If there is not proper tuning than it doesnt matter if you have iron ductile sleeves you will break them...Why was he running 13:1 compression without any sort of tuning??
Old Dec 8, 2002 | 10:47 AM
SiRkid's Avatar
so true....but for sure they can withstand a good amt of poower, tuned properly
Old Dec 8, 2002 | 11:04 AM
jinxproof99's Avatar
New User
i have had great experiences with stock b18c sleeves. inline has put incredible amounts of horsepower through stock sleeves with great success. tuning is the key. to me, the picture earl put up clearly shows what results from poor tuning, not necessarily the sleeves themselves. IMO.
Old Dec 8, 2002 | 01:08 PM
rOby's Avatar
Default Re: How weak are stock sleeves...Look inside (tygsr)
i dont see anythin wrong at all..less wall =less friction right?
Old Dec 8, 2002 | 01:16 PM
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (jinxproof99)
What startles me is that it is so easy to do this WITHOUT a turbo.
