How weak are stock sleeves...Look inside - Honda-Tech - Honda Forum Discussion
Old 12-07-2002, 09:17 PM   #1
earl's Avatar
Default How weak are stock sleeves...Look inside
Here is a B18C block that came in for repair today. It had CTR pistons and a milled head. Compression was close to 13-1. It lived less than a month without tuning. Now if this can happen to an N/A block, what could a turbo have done to it??
earl is offline   Reply With Quote
Old 12-07-2002, 09:22 PM   #2
Brrraaaap!
Blaze45's Avatar
Default Re: How weak are stock sleeves...Look inside (earl)
How come it wasnt tunned?
13:1= lots of tunning and premium gas ALWAYS.
Hope that dude learn'd his lession (to bad he had to learn it the hard way)
Blaze
Blaze45 is offline   Reply With Quote
Old 12-07-2002, 09:42 PM   #3
BoostedED9's Avatar
Default Re: How weak are stock sleeves...Look inside (Blaze45)
Blaze
no it would need race gas all the time.. 93 would not be enough
BoostedED9 is offline   Reply With Quote
Old 12-07-2002, 09:44 PM   #4
TheSwift1's Avatar
detonation can destroy ANY block...built or not...
what i would really like to see is a built block with built sleeves destoyed by detonation...anyone have any pics of that?
TheSwift1 is offline   Reply With Quote
Old 12-07-2002, 09:46 PM   #5
turbo craig's Avatar
Default Re: How weak are stock sleeves...Look inside (TheSwift1)
it kinda looks like a block guard woulda helped that...atleast a lil while longer till it was tuned
turbo craig is offline   Reply With Quote
Old 12-07-2002, 10:05 PM   #6
Tofurky's Avatar
Default Re: How weak are stock sleeves...Look inside (turbo craig)
ack. that makes me nervous about 14 psi....
Tofurky is offline   Reply With Quote
Old 12-07-2002, 10:06 PM   #7
BoostedED9's Avatar
Default Re: How weak are stock sleeves...Look inside (Ruckus138)
fine tunning is hte key to having a good runing motor
Old 12-07-2002, 10:07 PM   #8
2K_TEG's Avatar
earl,
what is up with those ridges? Looks like they are perfectly spaced?
2K_TEG is offline   Reply With Quote
Old 12-07-2002, 10:15 PM   #9
mos
mos's Avatar
Default Re: How weak are stock sleeves...Look inside (2K_TEG)
Looks like the ridges are from the aluminum part of the block that holds the sleeves, not in the sleeves themselves.
mos is offline   Reply With Quote
Old 12-07-2002, 10:27 PM   #10
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (mos)
Correct, I should have included the broken off piece in the pix also.
Old 12-07-2002, 10:33 PM   #11
2K_TEG's Avatar
ah...the picture is deceiving.
Old 12-07-2002, 10:57 PM   #12
Default Re: How weak are stock sleeves...Look inside (BoostedED9)
I know a lot of people running 91 on 13-1 no prob tuning is key
TREVER is offline   Reply With Quote
Old 12-07-2002, 11:01 PM   #13
Default Re: How weak are stock sleeves...Look inside (TREVER)
know and have met plenty of people running stock sleeved boosted b series motors. plenty of life in them also.
like stated above, any block can blow or break a sleeve such as above. even a fully built, sleeved block. too many factors.
bgod is offline   Reply With Quote
Old 12-07-2002, 11:02 PM   #14
Sonny's Avatar
Got JB Weld?
sonny
Sonny is offline   Reply With Quote
Old 12-07-2002, 11:04 PM   #15
Default Re: How weak are stock sleeves...Look inside (Sonny)
I agree that:
13:1 is do-able on 93 octane
detonation will kill a built or unbuilt motor
and I'll add that.. the odds of damage like this happening on an all motor car revving to 9500 and making say 200whp are much more likely than a turbo car revving to 8000 making 250whp.
trbob16a is offline   Reply With Quote
Old 12-07-2002, 11:28 PM   #16
SiRkid's Avatar
Default Re: How weak are stock sleeves...Look inside (trbob16a)
tuning..last time i read...gsr sleeve reportedly help up to 609 boosted whp..(posted by you earl?)
tuning tuning tuning.
thats the one thing im afraid of..is having my car tuned right.
SiRkid is offline   Reply With Quote
Old 12-08-2002, 12:18 AM   #17
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (SiRkid)
Not me on the 609whp. That's insane. I believe the number but what you don't hear is that the guy sold the motor to his buddy and he blew it up a few months later. It's not what you hear, it's what you don't hear about.
Old 12-08-2002, 12:20 AM   #18
HT's Biggest Loser
SIXTYdashONE's Avatar
AMEN Earl.......sooO true
SIXTYdashONE is offline   Reply With Quote
Old 12-08-2002, 09:00 AM   #19
Quick 200k Mile Motor's Avatar
Quote:
I agree that:
It is do-able, but it'll have to be severely retarded on the timing.
With high compression comes more heat.
It should be nothing above 12 on comp ratio for 93 octane.
Reason: detonation will creep up after driving around for a while.
That is often skipped for a daily street car.
Quick 200k Mile Motor is offline   Reply With Quote
Old 12-08-2002, 09:31 AM   #20
Optiks.'s Avatar
bahahahaha
Quote:
Got JB Weld?
sonny
Optiks. is offline   Reply With Quote
Old 12-08-2002, 11:44 AM   #21
tygsr's Avatar
Default Re: How weak are stock sleeves...Look inside (Optiks)
WEll the thing that decribes it best is " no tuning". I have heard of an seen many boosted b18's run 20+psi and not break a sleeve. If there is not proper tuning than it doesnt matter if you have iron ductile sleeves you will break them...Why was he running 13:1 compression without any sort of tuning??
tygsr is offline   Reply With Quote
Old 12-08-2002, 11:47 AM   #22
SiRkid's Avatar
so true....but for sure they can withstand a good amt of poower, tuned properly
Old 12-08-2002, 12:04 PM   #23
New User
jinxproof99's Avatar
i have had great experiences with stock b18c sleeves. inline has put incredible amounts of horsepower through stock sleeves with great success. tuning is the key. to me, the picture earl put up clearly shows what results from poor tuning, not necessarily the sleeves themselves. IMO.
jinxproof99 is offline   Reply With Quote
Old 12-08-2002, 02:08 PM   #24
rOby's Avatar
Default Re: How weak are stock sleeves...Look inside (tygsr)
i dont see anythin wrong at all..less wall =less friction right?
rOby is offline   Reply With Quote
Old 12-08-2002, 02:16 PM   #25
earl's Avatar
Default Re: How weak are stock sleeves...Look inside (jinxproof99)
What startles me is that it is so easy to do this WITHOUT a turbo.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
