switching from vortech to vafc/injector set up....have a couple ??'s
Old Dec 4, 2002 | 08:29 PM
boosted_dc2's Avatar
Default switching from vortech to vafc/injector set up....have a couple ??'s
i am currently running a drag 3 set up (7lbs.) with a walbro in tank 255, stock injectors, and a vorech 12:1. Over the winter im putting a thicker head gasket in and im going to run like 15 lbs next year. Ill be getting a vafc with 440cc rc injectors. My question is when running the vafc do i still need my missing link installed??? Also will i be able to tune my car so it will run stoich. with this set up??? any help is appreciated. I also assume that i will not need the vortech anymore.......is this right???
1994 gsr
Old Dec 4, 2002 | 09:48 PM
cock head's Avatar
Default Re: switching from vortech to vafc/injector set up....have a couple ??'s (hooked_up_gsr)
You have to take your missing link out. If you get it on a dyno i think you might be able, to get it to run stoich, and you do not need he fmu any more. you will also have the engine check light come on because the afc hack can only handle about 10-11 psi.
Old Dec 5, 2002 | 03:39 PM
Default Re: switching from vortech to vafc/injector set up....have a couple ??'s (therumblingteg)
what code will it throw???
Old Dec 5, 2002 | 04:19 PM
genop's Avatar
map sensor......the afc hack works by limiting the map voltage that the ecu "sees". If you go over 10-11psi you will go past the limits of the afc and the ecu will see boost....which will throw a code.
Old Dec 5, 2002 | 04:39 PM
Default Re: switching from vortech to vafc/injector set up....have a couple ??'s (genop)
is there any way around it??? what happens if i keep the missing link on???
Old Dec 5, 2002 | 04:53 PM
cock head's Avatar
you can up grader your map sensor to the gm, which reads up to 29 or so psi.
Old Dec 5, 2002 | 04:59 PM
how do i get one do you have a part number?? is it easy to wire???
Old Dec 5, 2002 | 05:04 PM
turbod16y8's Avatar
advance auto part has the GM map sensor.
Old Dec 5, 2002 | 05:10 PM
Default Re: switching from vortech to vafc/injector set up....have a couple ??'s (turbod16y8)
any gm map sensor???
Old Dec 5, 2002 | 05:16 PM
PressurizedSi's Avatar
Have you guys seen this V-AFC mod with 450cc injectors. It looks like it might work ok. Fine tuning could be accomplished with a wideband. What do you think? I'm thinking of trying it.
It would help if I posted the link.
http://www.thedropshop.tv/vafc.htm
[Modified by PressurizedSi, 6:19 PM 12/5/2002]
Old Dec 5, 2002 | 08:18 PM
cock head's Avatar
Re: switching from vortech to vafc/injector set up....have a couple ??'s (turbod16y8) (hooked_up_gsr)
__________________________________________________ _____________-
Go on hondata and check , I know they sell them so just check what kind they sell, but i think any will work.
wshondaman
Dec 24, 2004 01:45 PM
Tex Blackwell
May 17, 2004 09:15 AM
soulrider4ever
Feb 21, 2004 11:00 AM
boosted_dc2
Feb 25, 2003 11:38 AM
Evil EG
May 25, 2002 12:14 PM
