Crankshaft pulley bolt gone!
Old Dec 4, 2002 | 07:44 PM
jdm169's Avatar
Default Crankshaft pulley bolt gone!
Modified by jdm169 at 10:27 PM 11/24/2003
Old Dec 4, 2002 | 07:47 PM
Jaker's Avatar
Default Re: Crankshaft pulley bolt gone! (jdm169)
Its about 80 lbs/ft. Don't drive the car till its replaced, or you could totally screw things up.
Old Dec 4, 2002 | 10:17 PM
JDM CRX's Avatar
Default Re: Crankshaft pulley bolt gone! (Jaker)
yeah, i had the same problem in my first CRX,, ****** crank shaft pulley said "peace" while i was doing 70 on the highway. i pulled over and the engine was still runnning, so i was like, sweet,,,, went for 4 more blocks and then she let loose. blew the engine due to the timing belt moving over and nuking against the timing cover. i make sure that bolt is cranked on for dear life from now on!!!
Old Dec 5, 2002 | 05:26 AM
vtecrx's Avatar
Default Re: Crankshaft pulley bolt gone! (JDM CRX)
my helms says that the bolt for a crx should be at 119 ft lbs not 80. be sure to lube the threads with oil but dont get any non the washer contact surfaces.
Andy
Old Dec 5, 2002 | 09:40 AM
4GHB's Avatar
Default Re: Crankshaft pulley bolt gone! (vtecrx)
Andy
u are right on the tq specs
but not on the oil
put anti-seize before u ever put oil into the crank pulley bolt...!
Old Dec 5, 2002 | 01:37 PM
vtecrx's Avatar
Default Re: Crankshaft pulley bolt gone! (4GHB)
Andy
but not on the oil
im sorry but you are mistaken. I am looiking at my helms right now. It specifically says to use motor oil. It also goes on to say that if it is a new bolt that you should tourqe it to 145 ft lbs then loosen it and then tourqe it to 119 ft lbs. Where are you getting your information from?
Andy
Old Dec 5, 2002 | 02:19 PM
USDM 4G VTEC's Avatar
the manual says only to 145 if its new.. but doesnt say anything about putting oil into it...
Old Dec 5, 2002 | 02:41 PM
vtecrx's Avatar
Default Re: Crankshaft pulley bolt gone! (JDM EF9)
if the picture doesnt come up here is a picture that i copied out of my helms
http://www.imagestation.com/album/?id=4291055637
Andy
[Modified by vtecrx, 6:42 PM 12/5/2002]
[Modified by vtecrx, 6:43 PM 12/5/2002]
Old Dec 5, 2002 | 03:28 PM
CruxJDMB16A's Avatar
i work for honda and it doesnt matter what you torque it to as long as its tight the engine will tighten it up as you drive unless you have something seriously wrong
Old Dec 5, 2002 | 03:47 PM
vtecrx's Avatar
Default Re: Crankshaft pulley bolt gone! (CruxJDMB16A)
I'm really not trying to be an *** here but when you say that you work for honda do you mean that you are a tech there or that you actually design their engines? Personally I go by what the factory service manual says as opposed to what some tech that works for honda says.I am not saying that you are one but I have seen more than my fair share of honda techs tht I would not let anywhere near my car, let alone touch such as important part as the crank pulley. If you have the means to tourqe the bolt to the actual spec then do it, if not then find a way to make sure that that bolt is as tight as you can get it then take it somewhere and have them tourqe it for 5 dollars. But I am also the type who actually tourqes my valve cover, etc...
Just my $.02
andy
[Modified by vtecrx, 8:04 PM 12/5/2002]
Old Dec 5, 2002 | 04:20 PM
kshymkiw's Avatar
LOL, just cause you work for honda means you have all the answers. As was said i don't care who you are in Honda, I will trust the Helms manual.
Old Dec 5, 2002 | 04:35 PM
vtecrx's Avatar
Default Re: Crankshaft pulley bolt gone! (kshymkiw)
At least someone else agrees with me
Old Dec 5, 2002 | 05:18 PM
hybrid4dr's Avatar
that's always the worst when u hear rattling under the hood
Gibby1985
Sep 23, 2013 04:09 PM
iponnet
Feb 24, 2011 04:36 AM
ryanangelo212
May 23, 2009 08:36 PM
freshley
Jun 26, 2006 01:19 PM
PatrickGSR94
Nov 12, 2004 01:11 PM
