Hondata guru's.. need your help
Old Dec 4, 2002 | 04:18 PM
MeanGreenEG9's Avatar
Default Hondata guru's.. need your help
How do you reset the ecu back to stock after the hondata's blue box is removed.. I thought you just need to reset it the normal way but i think there is a jumper or chip inside the ecu that needs removing.. currently the car is running real shitty due to it running too rich and consiering the ecu was running maps for a turbo application i assume this is why... any help?
Old Dec 4, 2002 | 04:32 PM
Sonny's Avatar
Default Re: Hondata guru's.. need your help (Junek9)
Are you running stock injectors?
Sonny
Old Dec 4, 2002 | 04:45 PM
I heard you gotta take the jumper off j1... not sure where that is although I have found something on the ecu board that says J1.. but it doesn't look like a jumper.. looks more like a thin metal wire bridged to connected to j1 on the board.. should I just cut that in half??
Old Dec 4, 2002 | 05:26 PM
b19coupe's Avatar
That is it-that thin wire is the jumper. Desolder it or cut it.
non-VTEC
Engine Management and Tuning
Apr 25, 2009 06:50 AM
amalby
Apr 22, 2008 08:35 PM
Turbo-Honda
May 22, 2004 08:02 PM
