could you pass emissions with a obd1 ecu in an obd2 car?
Old Dec 4, 2002 | 02:29 PM
MeanGreenEG9's Avatar
Default could you pass emissions with a obd1 ecu in an obd2 car?
I'm thinking about going back to obd2 and ditching the obd2-1 harness becuase of emssions issue.. but I'm not sure.. if i were to just use say an obd1 stock p30 in an 96 civic i should pass emissions or would i have to convert it back to obd2 just for the test? anyone gone through this?
Old Dec 4, 2002 | 02:36 PM
Kataku2K3's Avatar
Default Re: could you pass emissions with a obd1 ecu in an obd2 car? (Junek9)
you know i'm not sure about it.... I was thinkin the same thing.... When they DEQ'ed my friend's EK/GSR they discovered that I didn't wire the EVAP solenoid and secondary oxygen sensor when i did his swap... Damn smart OBD2... I was gonna run a jumper and a P28 to see what would happen but then my friend just registered his car at school and now he doesn't have to DEQ it... Good Luck... Lemme know what happens... Latez
Old Dec 4, 2002 | 04:04 PM
Default Re: could you pass emissions with a obd1 ecu in an obd2 car? (JDMspecEG6)
well i dont plan on getting the test done anytime soon.. i'm just saying has anyone gone through this? bump again.
Old Dec 4, 2002 | 06:49 PM
jweller's Avatar
I think it depends largely on where you live. In Md if you pass the sniffer, you pass the test. any properly tuned OBD1 car should pass the sniffer.
Old Dec 4, 2002 | 10:27 PM
Louie's Avatar
What would Chente do?
Not sure where you live but in cali an obd-II vehicle will not pass with an obd-I ecu.
Old Dec 4, 2002 | 11:16 PM
Norcalstoppy's Avatar
Default Re: could you pass emissions with a obd1 ecu in an obd2 car? (Louie)
in california, no you won't. You could only put same or newer engine and components in your car.
jay Kim
GS-Racer X
Engine Management and Tuning
Jul 16, 2009 06:17 PM
ALLMOTOR CRX
Apr 20, 2007 10:10 AM
96MidoriHatch
10
Mar 7, 2005 06:11 PM
-1TSXer-
Aug 1, 2004 07:25 AM
iluznxpnoi
Mar 30, 2002 11:40 AM
