b-series pressure plate and flywheel bolts
Old Dec 4, 2002 | 01:42 PM
tilt's Avatar
Default b-series pressure plate and flywheel bolts
I'm going to be replacing my clutch and flywheel on my gsr. I know i need 12 point sockets but what are the metric sizes for both? Also any tips on removing and torqueing back on the bolts? Should I use any locktite - red or blue? tia
Old Dec 4, 2002 | 01:45 PM
Kamin's Avatar
Default Re: b-series pressure plate and flywheel bolts (tilt)
10 and 17 i belive. it could be 12's for the clutch.
its always a good idea to use a little loctite blue on the flywheel bolts. just in case.
Old Dec 4, 2002 | 02:05 PM
Kataku2K3's Avatar
Default Re: b-series pressure plate and flywheel bolts (KAMiN)
Yea they are a 10mm and a 17mm both 12pt.... I normally use Permatex Red high stregth high temp... It works hella good and is a pain in the *** to break off when you need to take the clutch and flywheel off again... It's worth it to me tho... Latez
Old Dec 5, 2002 | 12:50 PM
tilt's Avatar
Default Re: b-series pressure plate and flywheel bolts (JDMspecEG6)
thanks. I will probably go with some blue thread locker.
Also, for the shift linkage... Do i have to remove it at the tranny end by removing the small pin that holds it in? or can i remove the shift linkage at the shifter end?
Old Dec 5, 2002 | 12:55 PM
salbaje's Avatar
you would have to take off the pin or u can drop off with tranny
Old Dec 5, 2002 | 04:47 PM
ill phil's Avatar
Default Re: b-series pressure plate and flywheel bolts (salbaje)
Yeah pull the pin and drop the shift linkage and stabilizer
I used blue threadlocker too...
You're in Austin? Which car do you drive? I'm in Austin as well
Old Dec 5, 2002 | 07:57 PM
tilt's Avatar
Default Re: b-series pressure plate and flywheel bolts (ill phil)
thanks. It's a 94 milano red 2dr gsr
Old Dec 17, 2002 | 08:20 PM
tilt's Avatar
thanks. I got the new flywheel and clutch installed. Found out a metal piece around the clutch spring broke off and it was spinning around inside and causing my car to shudder. It engages so much smoother and i cant believe how fast it revs with the aluminum fly. It was a big pain to put the tranny back on... had to grab a couple buddies to get it all lined up.
[Modified by tilt, 5:21 AM 12/18/2002]
Old Dec 17, 2002 | 09:41 PM
IN VTEC's Avatar
Better make it a 10mm 12pt deepsocket. The shallow sockets won't clear the shoulders on the pressure plate.
Nevermind...I'm really laggin' here.
[Modified by IN VTEC, 12:42 AM 12/18/2002]
Old Dec 18, 2002 | 12:03 AM
ill phil's Avatar
Funny, thats the exact same thing I found when I pulled my transmission and replaced the clutch about 3 weeks ago. Congrats on getting everything installed and running again
Acidcrakker
Jul 3, 2012 05:35 AM
JDM turbo DC
Aug 28, 2007 07:42 PM
EG2Driver
Oct 7, 2006 07:50 PM
92integraVTECgsr
Apr 21, 2006 05:08 PM
JDM EJ1 95
Jun 10, 2005 07:29 PM
