B18B in EG..what engine harness?
Old Dec 4, 2002 | 01:17 PM
95hbMatt's Avatar
Default B18B in EG..what engine harness?
i'm putting a 96 b18b ls into my 95 hatch and i'll be using an obd1 P75 ecu....can I use the wiring harness off of my dx motor?
[Modified by 95hbMatt, 1:53 PM 12/5/2002]
Old Dec 4, 2002 | 01:39 PM
HXMan's Avatar
Default Re: B18B in EG..what engine harness? (95hbMatt)
Stock civic harness.
Old Dec 4, 2002 | 02:03 PM
Kataku2K3's Avatar
Default Re: B18B in EG..what engine harness? (HXMan)
Either will work... The LS will plug straight in... If you use the Civic harness you'll have to rework it for the LS motor and you'll also have to rewire the distributor and injector connectors... Good Luck
Old Dec 4, 2002 | 02:14 PM
95hbMatt's Avatar
Default Re: B18B in EG..what engine harness? (JDMspecEG6)
what does the rewiring entail..is it a pain in the ***...?? should I just go ahead and buy a wiring harness from an obd1 ls motor?
Old Dec 4, 2002 | 02:24 PM
Kataku2K3's Avatar
Oh no... it's not bad at all..... I personally would rather rewire except for the fact that I like my wiring absolutely perfect and cutting the plug off the LS distributor and reconnecting the Civic just doesn't look totally stock... As for the injectors you will need to still get the OBD2 style connectors or you can just use your Civic injectors... They are all the same cc..... If you have to buy a new LS harness then just rewire the Civic but if you had the LS harness on it now it will just plug straight into your car.... Hope this helps... Latez
[Modified by JDMspecEG6, 3:26 PM 12/4/2002]
Old Dec 4, 2002 | 03:06 PM
95hbMatt's Avatar
cool..thanks...I guess i'll save my money and use my civic harness...
is the rewiring difficult or is it pretty straight foward...?? is the distributor plugs the only things i have to swap over?
Old Dec 4, 2002 | 11:42 PM
Kataku2K3's Avatar
The wiring is really pretty straight foreward... When I do it i normally make it more complicated for myself cuz like I said I like this **** perfect.... I pull the entire loom apart, add and extend any wires that I need to then reloom it with new loom and wrap it back up so that it looks stock.... The distributor is really the only thing you have to rewire... You should just be able to do it by matching wire colors... As for the injectors it just depends on what you wanna use... If you use your stock Civic ones you won't have to rewire the connectors but if you choose the keep the LS then you'll need 96+ plugs.... I personally like the new plugs better because they look cleaner and are easier to take off... Also when i wire up the connectors at the engine loom to the interior loom i normally add pins in there so that you can just pull the connector apart... You don't have to do this if you have to add any wires in, just hard wire them if you want.... I think i just do this **** cuz i'm weird.. but yea... Hope this helps Latez
Old Dec 5, 2002 | 10:15 AM
B18C-EJ1
Guest
Posts: n/a
i'm putting a 96 b18b ls into my 95 hatch and i'll be using an obd1 975 ecu....can I use the wiring harness off of my dx motor?
Just use the 96 LS engine harness.
Bam, you're done.
Old Dec 5, 2002 | 01:08 PM
salbaje's Avatar
yea use the 96 Ls harness with the obd1 p75 it should all plug in. you might have to run a wire from dist to driverside tower for the tach
Old Dec 5, 2002 | 01:30 PM
HXMan's Avatar
Sorry...yea you can use the LS harness. I forgot they plug into eg's.
Old Dec 5, 2002 | 01:41 PM
Kataku2K3's Avatar
Well I'm sayin just use the stock Civic harness to save money.... If he doesn't care about that, then yes the LS harness is cheaper and will plug in just as i have always said...
Old Dec 5, 2002 | 01:42 PM
blacksheep's Avatar
Maybe I'm just ignorant on this subject, but I didn't know that a 96 engine would plug in to a 95 car. I thought it would just be easier to get a 94-95 B18B1 and it would just plug right in. Maybe I'm wrong though.
Old Dec 5, 2002 | 01:45 PM
salbaje's Avatar
Default Re: B18B in EG..what engine harness? (blacksheep)
yes it will plug into a 95 car.
Old Dec 5, 2002 | 01:49 PM
Kataku2K3's Avatar
Default Re: B18B in EG..what engine harness? (salbaje)
They are the same thing... The only thing that is different is the distributor plug and injectors... If you did this you'll have to rewire the connectors just as you would on the Civic harness...
Old Dec 5, 2002 | 04:29 PM
B18C-EJ1
Guest
Posts: n/a
No you don't. Whoever told you that was wrong.
Old Dec 5, 2002 | 04:30 PM
B18C-EJ1
Guest
Posts: n/a
You're wrong. (not being a dick, just stating fact)
Plug and play.
Old Dec 5, 2002 | 04:34 PM
Kataku2K3's Avatar
Default Re: B18B in EG..what engine harness? (B18C-EJ1)
What are you talkin about???? So you are telling me that the 94-95 harness will plug onto the 96+ style injectors... Unfortunately I did my friend's LSVTEC for his 94 Integra a couple months ago and I had to rewire the injectors since we were using 2000 Si head... Same injectors as on the 96+ ****... Also had to rewire the distributor plug...
Old Dec 5, 2002 | 04:36 PM
B18C-EJ1
Guest
Posts: n/a
No, what I'm talking about is a 96-00 Integra LS engine harness is PLUG AND PLAY into a 92-95 Honda Civic Chassis harness.
Then you use a OBD1 LS ecu (PR4, P74, P75) and call it a day.
Understand?
PS, this is not a 96-00 Civic swap, it's for a 92-95 Civic as stated in the first post.
We all know they are different, and please don't compare the 2 swaps. Let's just get the original thread starter the CORRECT information.
[Modified by B18C-EJ1, 5:37 PM 12/5/2002]
Old Dec 5, 2002 | 04:38 PM
Kataku2K3's Avatar
Yes i already knew this... When did i ever say that it wouldn't?? Latez
Old Dec 5, 2002 | 04:55 PM
B18C-EJ1
Guest
Posts: n/a
Then why do you even bother to bring it up?
HELLO.....
McFLY! Are you in there....
Why is it, you feel it necessary to start an arguement about "OTHER" swaps, and not stick to the subject at hand?
You could have just told this guy, that the 96 LS engine harness would plug right into his EH chassis, and it would be that easy.
But no, you had to whip your DICK out, and show everyone who is reading this how much of a man you are and how much you know.......
[Modified by B18C-EJ1, 5:55 PM 12/5/2002]
Old Dec 5, 2002 | 08:01 PM
95hbMatt's Avatar
cool...thanks fellas...so now I need a 96 obd2 LS engine wiring harness....anyone out there have one for cheap..hook a bro up!
Old Dec 5, 2002 | 08:51 PM
B18C-EJ1
Guest
Posts: n/a
Matt,
Check ebay and partstrader.com
I've seen them for as little as $20 + ship.
Old Dec 6, 2002 | 07:03 AM
95hbMatt's Avatar
ey thanks alot B18C-EJ1 and to all the others than aided in this post....well hopefully i'll be posting up soon on my swap...
j4s0n1337
19
Jul 21, 2019 06:47 PM
Eklsv-t
Northern California (Sales)
Aug 13, 2009 01:16 AM
hYbRid_Eg6
Apr 16, 2009 09:44 PM
bettsbanger
Feb 2, 2009 03:07 PM
polyphony_digital
Jun 8, 2004 05:54 PM
