Honing the cylinders.....
Old Dec 3, 2002 | 04:45 PM
Turbo Powa's Avatar
Default Honing the cylinders.....
Is there a way I can hone my own cylinders? Any info will be appreciated!!
Old Dec 3, 2002 | 05:17 PM
Turbo Powa's Avatar
Default Re: Honing the cylinders..... (Panda EK)
anyone?????
Old Dec 3, 2002 | 05:32 PM
mmuller's Avatar
Mad Scientist
u can buy the honing rocks at any auto parts store, but make sure u do it right
Old Dec 3, 2002 | 05:39 PM
Turbo Powa's Avatar
Default Re: Honing the cylinders..... (mmuller)
And how can I do it correctly?
Old Dec 3, 2002 | 06:29 PM
Turbo Powa's Avatar
to the top again~!
Old Dec 3, 2002 | 10:23 PM
tnbigdawg's Avatar
when you hone the cylinders, dont do it too long cause you are actually increasing the bore a little...when doing this, make sure you use oil to lube the cutting process. after doing this, your gonna have to get your block cleaned out of any metal shavings by hosing the bare block down with water...then dry it right after and wipe it down with wd-40 to keep it from rusting.
Old Dec 4, 2002 | 05:21 AM
Turbo Powa's Avatar
Default Re: Honing the cylinders..... (tnbigdawg)
thanks for the info!! If anyone else know how to do this let me know.
Old Dec 4, 2002 | 05:33 AM
nolimits's Avatar
The hone should be 3 stones on a spring loaded arm with a shank for a drill. Keep the hone moving up and down to create a crosshatch pattern and smooth out imperfections in the cylinder. It needs a consistent oil coating or it may scar the cylinder, requiring to hone more. You need to use a micrometer to measure cyl diameter to see if it's still within specs. If its too large you will need to bore and get new pistons
Old Dec 4, 2002 | 06:26 AM
jlicrx's Avatar
take it to a machine shop! - yes, you can do it yourself, but the open deck honda cylinders are difficult to hone perfectly round, even with a machine - the closer you can get to perfectly round, the less leakdown you will have - less leakdown = more horsepower.
Old Dec 4, 2002 | 06:35 AM
rastropovitch
Guest
Posts: n/a
If you want to do it right, have a shoppe do it in a boring machine. The finished pattern should look like a X pattern on the cylinder walls. It needs to be done in several incremental steps, do not try and take all material off at once. Use a In and out motion, like your f*cking the cylinder. And please make sure the block is cleaned, including all oil passages.
Peace
Schu
Old Dec 4, 2002 | 09:12 PM
Vertigo's Avatar
Default Re: Honing the cylinders..... (MSchu)
Machine shop
I did the bore myself, and could not take but so much off. Finally took it to the machine shop.
[Modified by Mjay, 1:18 AM 12/5/2002]
Luward
Dec 22, 2013 06:06 PM
Reza^
May 22, 2007 10:24 AM
290allen
10
Aug 1, 2006 11:08 PM
pubestripe
Dec 17, 2004 10:48 PM
92BlackSi
Aug 31, 2003 08:41 AM
