Few syncro questions
Old Dec 2, 2002 | 03:19 PM
Nameless RB26's Avatar
Default Few syncro questions
I think I'm gonna replace my 4th gear syncro.
My tranny is JDM. Is there any difference between US and JDM syncros?
How much does a scyncro cost?
And can someone post a pic of the inside of a B series tranny? Just cause I like pics..
Old Dec 2, 2002 | 03:24 PM
sackdz's Avatar
Default Re: Few syncro questions (Nameless)
Since you asked for them I don't have to resize them right?
3-4 Synchro.... kit.. Should be like 100 bux I forget.
Old Dec 2, 2002 | 03:26 PM
Default Re: Few syncro questions (sackdz)
That'll do! Thanks.
Anyone else have input?
Old Dec 2, 2002 | 03:28 PM
Wait. What does the syncro look like? Is it in that pic?
Old Dec 2, 2002 | 03:32 PM
sackdz's Avatar
Yep, it's on the shaft on the left... count 1 straight and 2 helical gears from the bottom, then is the synchros rings (brass colored) and collar( wide groove for shift fork). You hsould replace at a minimum the rings if not the collar. The synchro hub should be fine.
Old Dec 2, 2002 | 03:37 PM
Hmm. What is the difficulty level of replacing that? Is it something I should take to a specialist?
Thanks btw
Old Dec 2, 2002 | 03:41 PM
sackdz's Avatar
Depends on your ability. I did it myself w/o much experience in anything... but I'm not mechanically retarded. I wouldn't reccommend doing it if
a)You're retarded
b)You're on a tight schedule to get it done
c)You don't have a helms
You always got h-t to help but if you're not comfortable then you might want to have someone else do it.
Old Dec 2, 2002 | 03:44 PM
ok. Last couple things.
What numbers locate the replacement part/s? Is this even the right pic?
And, what type of tools would I need? Gear puller and **** like that?
Old Dec 2, 2002 | 04:23 PM
Hey where'd you go!! I thought we were on a roll here!!
Old Dec 2, 2002 | 10:10 PM
Titty
Old Dec 3, 2002 | 04:12 AM
sackdz's Avatar
Titty
That pic is the counter-shaft with the 1-2 sycnhro.
Here is what you are looking for. You want Part #9
$158.92
Old Dec 3, 2002 | 05:48 AM
Thanks
Old Dec 3, 2002 | 05:56 AM
AssPenny's Avatar
I went over this in another thread, it was found out that you can't just order #9, you have to order #4 at around $240
Here is a link to the thread: https://honda-tech.com/zerothread?id=300141
Old Dec 3, 2002 | 06:04 AM
sackdz's Avatar
Default Re: Few syncro questions (AssPenny)
I ordered just #9. ...From Mike K awhile back.
James_Starks
11
Sep 16, 2010 04:42 PM
92-LS-Civic
Jun 4, 2005 10:44 AM
legendboy
Mar 1, 2004 10:47 PM
Blown90hatcH
Jan 9, 2004 02:34 PM
squirrel
Feb 20, 2003 04:55 PM
