turning crank
Old Dec 2, 2002 | 10:56 AM
tilt's Avatar
Default turning crank
I am posting this for a friend. He is having the weirdest problem with his 97 civic manual. He is trying to set his timing to TDC before he works on it, but he says he cant turn the crank no matter what. The car is in neutral, the spark plugs are out, and he's removed all the other drive belts cept the alternator and timing belt. Everything checks out from what he's told me and I cant think of why it would do this... anyone?
Old Dec 2, 2002 | 11:00 AM
Spade's Avatar
Default Re: turning crank (tilt)
Doesn't sound good.
I know you already did but, I suggest verifying it is neutral.
Old Dec 2, 2002 | 11:20 AM
Crazydave's Avatar
Default Re: turning crank (Spade)
he's not pushing hard enough
Old Dec 2, 2002 | 11:29 AM
Desslok's Avatar
Default Re: turning crank (Crazydave)
I do mine w/ the plugs in and belts on, so yes make sure it's in neutral or park.
Old Dec 2, 2002 | 11:40 AM
tilt's Avatar
Default Re: turning crank (sp)
Ok i just asked him how hard he is pulling and he says about 80lb/torque, so I know he is pulling hard enough. Another thing is he says it wont even budge 1 cm so i know it's not the gears holding it in place.... gears would let you move it a little bit then keep it from turning. Is it possible the head/valves are jammed somehow?
Old Dec 2, 2002 | 11:51 AM
jolt's Avatar
With it in gear, can he roll the car forward till its in TDC?
Old Dec 2, 2002 | 12:01 PM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
what did the car do? What is he trying to fix?
Old Dec 2, 2002 | 12:09 PM
tilt's Avatar
Default Re: turning crank (1bad_EF)
The car was working fine... he just wants to change the timing belt since it's about that time for recommended replacement.
Old Dec 2, 2002 | 01:15 PM
keebler65's Avatar
well if the car starts, the crank can obviously turn. i'd say he's not turning it hard enough even though you said otherwise.
Old Dec 2, 2002 | 02:10 PM
tnbigdawg's Avatar
Default Re: turning crank (keebler65)
i think his pistons are hitting the valves.
Old Dec 2, 2002 | 06:38 PM
Turbo Powa's Avatar
Default Re: turning crank (tnbigdawg)
huh?
Old Dec 2, 2002 | 07:15 PM
94TealGSR's Avatar
What's he trying to use to turn it? I've got a 25" breaker bar that works well. He probably just isn't pushing it hard enough. If you can start it there obviously isn't anything stopping it from turning.
Old Dec 2, 2002 | 10:42 PM
tnbigdawg's Avatar
Default Re: turning crank (Panda EK)
huh?
well, i figure that if he's trying to turn the crank and the valves are open....then wouldnt the piston hit it....making the crank hard to turn???
Old Dec 3, 2002 | 02:47 AM
Mista Bone's Avatar
D Tranny Guru
like he has already removed the timing belt and trying to rotate the crank without moving the cam.
Old Dec 3, 2002 | 06:54 AM
tilt's Avatar
Default Re: turning crank (Mista Bone)
ok, he used a 4 ft pipe and he got it to turn. He said it went "pop" (i dont understand why it would do this) and after that it now moves freely.
Old Dec 3, 2002 | 08:11 AM
1bad-eg's Avatar
make sure you didn't break any valves. It sounds to me that your friend took the t-belt off before setting the engine on tdc.
Jimster480
Nov 28, 2010 08:34 PM
zuruk
Jan 15, 2009 05:15 AM
ftrms
Nov 19, 2008 06:20 PM
Rod.
May 26, 2004 09:51 AM
ITR9788
Jan 20, 2004 02:51 AM
