pump oil pump - exactly how does it work?
Old Dec 2, 2002 | 09:28 AM
serious's Avatar
Default pump oil pump - exactly how does it work?
exactly how, mechanically, do honda oil pumps work?
Old Dec 2, 2002 | 11:22 AM
Crazydave's Avatar
Default Re: pump oil pump - exactly how does it work? (serious)
it's a gear that sits inside a bigger cog
as the gear turns.. the space between the gear & cog open up sucking oil in.. and then as it rotates it closes forcing the oil out
Old Dec 2, 2002 | 11:26 AM
Desslok's Avatar
Default Re: pump oil pump - exactly how does it work? (Crazydave)
SOunds like a Mazda Rotary engine.
Old Dec 2, 2002 | 11:38 AM
serious's Avatar
so the gears don't actually mesh?
Old Sep 28, 2008 | 10:58 AM
Acidcrakker's Avatar
exactly how is it driven to suck the oil up. I was always under the impression that it runs off the balancer belt. I even took apart a block last night and mildly examined it.
There is a front and rear balancer shaft. The rear shaft looks like its intertwined with the oil pump.
Im looking to rid the h22 of the balance shaft and someone told me to just cut the balance shaft belt. I dont think thats what Im looking for.
I know kazienspeed makes a delete kit. But how does the oil pump drive.
Old Sep 29, 2008 | 02:10 PM
Crazydave's Avatar
Default Re: pump oil pump - exactly how does it work? (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">exactly how is it driven to suck the oil up. I was always under the impression that it runs off the balancer belt. I even took apart a block last night and mildly examined it.
I know kazienspeed makes a delete kit. But how does the oil pump drive. </TD></TR></TABLE>
ON the D-series.. the oil pump is driven directly from the crank.
On the other engines you might be correct, I think they are driven off the balancer belt
Old Sep 29, 2008 | 02:22 PM
srmofo's Avatar
I know the older accords (early 90s)had the oil pump driven by the balancer belt,but I cannot speak personally for a newer one
Edit - why do you want to rid the engine of the balancer belt? Its there for a reason and vibrations will wipe your bearings out with a quickness
Old Sep 29, 2008 | 07:37 PM
lude98SH's Avatar
Its turn directly by the crank
stemcellsrock
Apr 29, 2019 06:24 PM
PARADOX_sf
Jul 23, 2009 11:43 AM
OaksRacing
Oct 8, 2005 09:52 AM
PROFILES2000
Feb 25, 2002 01:17 PM
