Speaker wire ground wire?
Old Dec 1, 2002 | 02:19 PM
RAF LTD.'s Avatar
Default Speaker wire ground wire?
I read somewhere else on the board that speaker wire is a better ground for the engine than the stock ground wire. Could someone please post how to make a better ground using speaker wire (if possible).
Old Dec 1, 2002 | 02:22 PM
10K2HVN's Avatar
Default Re: Speaker wire ground wire? (RAF LTD.)
SAME **** MAN! As long as you have the right gauge...i use Street Wires 8 gauge for my head ground. Looks better then stock. + it was the only thing i had around!
Old Dec 1, 2002 | 05:31 PM
RAF LTD.'s Avatar
Default Re: Speaker wire ground wire? (10K2HVN)
thanks, how did you install it?
Old Dec 1, 2002 | 05:58 PM
tinkerbell's Avatar
if you read it somewhere on here --> SEARCH?
https://honda-tech.com/zerothread?id=345384
here is a picture anyways,
make it like that using 8 gauge power cable with gold connectors.
for your gearbox/block earth use 4 gauge cable
(try your local radioshack)
t..
EG-SIXV-TEC
Oct 19, 2009 01:45 PM
thejacka
Audio / Security / Video
Jul 10, 2006 11:03 PM
potatostix
Mar 31, 2006 01:27 PM
miksew
Feb 19, 2004 01:06 PM
garyyam
Oct 22, 2002 04:05 PM
