best sohc-vtec motor
Old Nov 28, 2002 | 08:14 PM
accord5speed's Avatar
Default best sohc-vtec motor
whats the best sohc vtec motor they made, what model did it come in ,thanks
Old Nov 28, 2002 | 08:18 PM
All_Lag's Avatar
Default Re: best sohc-vtec motor (accord5speed)
in my opinon
D16y8
Comes in Civic Ex 96-00.....im pretty sure
Old Nov 28, 2002 | 08:21 PM
piscorpio's Avatar
92-95 Civic Si/EX - d16z6 125hp
96-00 Civic EX - d16y8 127hp
I think most people would argue the z6 is best, because I believe it has a stronger bottom end and also because it is OBD I and not OBD II like the y8. However, the y8 is supposed to have improved head design over the z6, so some people have opted to swap heads. They are both pretty similar, and if you go one or the other you probably won't be missing out on much. Of course one big advantage of the y8 is that it will be newer.
[Modified by piscorpio, 11:23 PM 11/28/2002]
Default Re: best sohc-vtec motor (Apexi99ex)
thats the motor that i was thinking was the best , also i dont know that much about sohc vtec's how much would a swap run me? bout 800-850 with everything needed and with less than 60k miles on it, is that a resonable price?
[Modified by accord5speed, 5:24 AM 11/29/2002]
Old Nov 28, 2002 | 08:36 PM
UpstateCivic's Avatar
Check my sig.
Old Nov 28, 2002 | 08:39 PM
Eee Pee's Avatar
Default Re: best sohc-vtec motor (UpstateCivic)
D15B from Japan.
1.5 liter, v-tec head.
130 hp. Sometimes factory LSD.
Old Nov 29, 2002 | 12:44 AM
civicsitek GanGsTa's Avatar
Default Re: best sohc-vtec motor (E Prep)
Spade has a great thread on sohc performance. I currently have a z6 Im building at work. d16a1 pistons= 12:1 compression, balanced and blueprinted bottom end with stock shotpeened and polished rods, skunk2 retainers, crower valve springs and camshaft, it should be a runner when its done, that and it was cheap to build. Im hoping to rival stock gsr performance.
Old Nov 29, 2002 | 12:53 AM
EddieHatchBlack's Avatar
D15B from Japan.
Great motor! My friend had it in his RHD 95 VTi. Now he's rocking c5.
Old Nov 29, 2002 | 12:57 AM
bretx0r's Avatar
Default Re: best sohc-vtec motor (Eddie HatchBlack)
d16y5.
1996-00 HX.
roller rockers. bigger cam. lower compression? big whoop, the only reason honda posted lower horsepower figures than the EX is to sell more EX's. HX is more powerful, i roasted plenty of EX's stoplight and highway races when i was N/A (intake, muffler) and ran a 15.6@86 with just those mods.
[Modified by bretx0r, 9:59 AM 11/29/2002]
ajason24
19
Aug 18, 2013 07:40 AM
96CIVICEX
12
May 8, 2009 09:26 AM
hondanut
Jun 7, 2007 08:17 PM
mawkiemarc
63
Mar 30, 2005 06:32 PM
static_signal
Nov 25, 2003 04:45 AM
