cat convertor keeps pulling a code 67.
Old Nov 28, 2002 | 07:06 PM
Ibuprofen's Avatar
Default cat convertor keeps pulling a code 67.
i'm running a jdm 2.5 cat convertor and the check engine light keeps coming on every 60-100 miles or so. Is there anyway to disable the o2 sensor in the cat or prevent it from pulling that code repeatedly?
Old Nov 28, 2002 | 08:35 PM
Reid's Avatar
Global Moderator
Default Re: cat convertor keeps pulling a code 67. (2000integragsr)
If you have a plug for the o2 in the cat I can disable the cel for you. And it will never come on. I'll do it for
What exactly do you do that prevents it from throwing a code 67?
Old Nov 29, 2002 | 07:46 AM
Komsomol's Avatar
Default Re: cat convertor keeps pulling a code 67. (Reid)
I have this same problem. Please tell us how to get rid of annoying check engine light.
Old Nov 29, 2002 | 12:53 PM
CivicEK.PDX's Avatar
Default Re: cat convertor keeps pulling a code 67. (8400RPMS)
I have my O2 sensor sitting in my car on the floormat. no CEL from it.
Old Nov 29, 2002 | 03:15 PM
Reid's Avatar
Global Moderator
Default Re: cat convertor keeps pulling a code 67. (CivicEK.PDX)
How did you prevent it from throwing a code 67?
Old Nov 29, 2002 | 03:34 PM
R-1303's Avatar
Plug the secondary o2 in the cat with an bolt..i forgot which size..or you can buy a ecg (i think) secondary o2 tricker which tricks out the secondary o2..just wrap the secondary o2 in foil and then plastic and hang it somewhere....thats what got rid of my cel 67...
Old Dec 11, 2002 | 12:04 AM
Ibuprofen's Avatar
Default Re: cat convertor keeps pulling a code 67. (R-1303)
terrific.
any other suggestions? gonna take try to fix it this weekend...
Old Dec 11, 2002 | 12:06 AM
underrated99si's Avatar
Default Re: cat convertor keeps pulling a code 67. (01-0531)
COnvert to OBD1 solved my prob
spray_bombed
Jul 22, 2007 04:14 PM
Frostwhite_DB8
Jun 2, 2007 09:33 AM
DVS Luder
Feb 19, 2006 09:31 AM
carroljb
Oct 8, 2004 04:33 AM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
