Cel Code 45, Already searched
Old Oct 7, 2004 | 02:40 PM
carroljb's Avatar
Default Cel Code 45, Already searched
My check engine light is on and I checked the code and it gave me 45. I know that is means that I am running too lean or too rich. What can I do to fix it?
Old Oct 7, 2004 | 04:10 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Cel Code 45, Already searched (carroljb)
When I got that code my cat was bad. Check your cat to see if there is any blockage. One of the "blocks" inside of my Carsound cat crumbled and blocked the air flow in front of the secondary o2 sensor.
Good luck!
Old Oct 7, 2004 | 04:15 PM
Im_In_There's Avatar
Default Re: Cel Code 45, Already searched (Gee3)
MY car has been throwing the same code for a while now. In my situation it wasnt the cat because i had it with my old exhaust and header combo as well. I think in my case it has something to do with the comptech computer that its installed in the car. I will switch back to the stock computer to see if it goes away.
Old Oct 7, 2004 | 05:20 PM
quikrpm'z's Avatar
i changed my primary o2. Fixed the code, but i can feel that the car is running a bit lean.
Old Oct 8, 2004 | 04:25 AM
Default Re: Cel Code 45, Already searched (quikrpm'z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikrpm’z &raquo;</TD></TR><TR><TD CLASS="quote">i changed my primary o2. Fixed the code, but i can feel that the car is running a bit lean.</TD></TR></TABLE>
I did that as well and for a bit it was fine and then it just came back. My plugs are white too so im guessing is also really lean.
Old Oct 8, 2004 | 04:33 AM
Finland's Avatar
I say with high probability that your primary O2 is bad, or contaminated. Change it.
DJ Gurgla GSR
May 30, 2006 12:50 PM
DVS Luder
Feb 19, 2006 09:31 AM
impr323
Jun 21, 2005 05:29 PM
Ibuprofen
Dec 11, 2002 12:06 AM
LillDragun
Jul 11, 2002 05:47 PM
