CEL Code : P0420
Old Apr 14, 2007 | 07:11 PM
Frostwhite_DB8's Avatar
Default CEL Code : P0420
"Catalyst System Efficiency Below Threshold "
Had ektuner39 on the forum ran his scanner for me and this code pulled up. The code says :
1. 3 way Cat Converter
2. Secondary o2 sensor
3. Exhaust system leakage
I believe it's one of the possible 3 above that is causing my CEL to come on. We reset the light after the scan and it came back on a week later. Should I just go ahead and replace the secondary o2 sensory ? If it's the cat , shouldn't I be getting bad gas mileage ? I still average 300 miles to the tank with the light on. Thanks any help would be nice.
Old Apr 15, 2007 | 10:31 AM
BUMP
Old Apr 15, 2007 | 11:09 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: CEL Code : P0420 (Frostwhite_DB8)
Is the cat stock?
Old Apr 15, 2007 | 11:44 AM
Yes and everything else.
Old Apr 15, 2007 | 12:42 PM
Default Re: (Frostwhite_DB8)
I will check alldata at work, its a common code for nissans but a honda application may be a different fault. Usually a cat code is due to the secondary o2 sensor (post cat) verifying the cat isnt functioning properly.
Old Apr 15, 2007 | 09:50 PM
Bump.
Old Apr 16, 2007 | 07:51 AM
Looked it up, you either have an exhaust leak or your cat is inefficient. Process of elimination but if you havent touched the exhaust system id say you dont have a leak, cat is probably bad... odd.
Old Apr 16, 2007 | 12:16 PM
Default Re: CEL Code : P0420 (ForceFed_Motorsports)
Guess I'll go ahead and order a new cat and o2 sensors. Thanks ForceFed
Old Apr 16, 2007 | 03:20 PM
No problem.
Your o2's are more than likely ok, they can test them if you dont have the means to do so using a scope. Your cat sounds like its the cause.
Old Apr 20, 2007 | 01:32 AM
What the... My CEL went away tonight. It was still on when I went to the gym...2 hours later , went to my car , started her up and behold... No CEL ! Now I'm confused.
Old Apr 20, 2007 | 06:14 AM
A code will clear itself if it falls within the drive cycle criteria, meaning if the car acts a certain way for an alotted period of time the code will clear. Doesnt mean the problem went away, just that it was corrected for that trip. That should be a two trip code.
Old May 31, 2007 | 04:17 PM
Default Re: (ForceFed_Motorsports)
Sigh...Back up again... Replaced both front & rear O2 sensor , catalytic converter ( magnaflow oem spec CA OBDII approved ).. What is left ?
Old May 31, 2007 | 07:32 PM
Ill look into it tomoro when i get to work. Seems odd that it would return. How does the car run itself?
Old Jun 1, 2007 | 04:20 PM
The car itself runs fine.. I drive 80 miles a day to work and back home.
Old Jun 2, 2007 | 09:33 AM
Im assuming you have already checked for exhaust leaks, or would have heard one.
Whatislove
Honda Civic (2001 - 2005)
16
Jan 31, 2011 11:17 AM
Ibuprofen
Dec 11, 2002 12:06 AM
LillDragun
Jul 11, 2002 05:47 PM
LillDragun
Jul 6, 2002 08:04 PM
