LsVtec Problems Help ASAP???????
Old Nov 24, 2002 | 06:37 PM
B20zvtecek's Avatar
Default LsVtec Problems Help ASAP???????
Ok just put in an lsvtec (00 si head, 95 ls block) into a 96 DX hatchback
It fired up on the first crank , but idles like ****
Itll idle at 1000rpm for about 30 seconds, and they repedidly bounce from 2-3 over and over , idle control vavle is hooked up and working
When we give it some gas it wants to die
Is this because we havent hooked up any O2 sensors????
If not what is it? Thanks alot in advance
Old Nov 24, 2002 | 08:28 PM
salbaje's Avatar
Default Re: LsVtec Problems Help ASAP??????? (B20zvtecek)
is it throwing code?? check timing
Old Nov 24, 2002 | 09:38 PM
b19coupe's Avatar
Did you cross MAP and TPS sensor connectors ? It happens.
Old Nov 24, 2002 | 09:43 PM
3rdGteg's Avatar
Default Re: LsVtec Problems Help ASAP??????? (b19coupe)
That's what it sounds like.
joshuma
Sep 2, 2008 05:37 AM
crxspoonb18c5
Jun 18, 2008 02:21 PM
97ekb18b
11
Mar 13, 2008 06:32 PM
95teilhatch
Apr 7, 2007 10:29 PM
baked_beanz
12
Feb 10, 2005 10:12 AM
