flashing abs light
Old Nov 24, 2002 | 11:20 AM
andrewasf77's Avatar
Default flashing abs light
hello again, another question from me, "the rookie". i did a search and couldnt find much. i was checking my cel code and when i did that the abs light started flashing also, is this normal? i looked at it and it gave a single long flash, followed by 6 short flashes. any reason why?
Old Nov 24, 2002 | 01:05 PM
owen_the_soyboy's Avatar
Default Re: flashing abs light (andrewasf77)
that is the ABS trouble code. great huh, always something
Old Nov 24, 2002 | 04:32 PM
vactor's Avatar
why not just check the codes via the helms? no big deal ...
Old Nov 24, 2002 | 04:36 PM
Default Re: flashing abs light (owen_the_soyboy)
do you know what that abs trouble code means? i know the check engine light is the secondary o2 sensor, but i never knew the abs light flashing meant something too.
Old Nov 24, 2002 | 06:03 PM
stRtypR25's Avatar
Default Re: flashing abs light (vactor)
on what page in the helms manual are the codes listed for the ABS light?
Old Nov 24, 2002 | 06:41 PM
Default Re: flashing abs light (stRtypR25)
im not sure, i thought that all engine codes went through the cel, but now when i checked my cel code, my abs light started to flash a code 16????
Old Nov 24, 2002 | 06:51 PM
EndlessGarageEG6's Avatar
My abs flashes when the brake pads are low. Might wanna check those.
Edit: But the best thing to do is to check the code in the helms manuel.
[Modified by CRintegreX, 7:53 PM 11/24/2002]
Old Nov 24, 2002 | 06:52 PM
Default Re: flashing abs light (CRintegreX)
it doesnt flash when the car is running, only when i was checking the cel code
Old Nov 24, 2002 | 07:48 PM
Chris's Avatar
NO it doesnt, thats the HANDBRAKE light.
Old Nov 24, 2002 | 08:08 PM
b19coupe's Avatar
Default Re: flashing abs light (Chris)
When the brake fluid is low, it can cause the red "brake " light on the dash to come on. That can also trigger an ABS code. I will check at work tomorrow what ABS code #16 represents.
Old Nov 25, 2002 | 09:24 AM
b19coupe's Avatar
Default Re: flashing abs light (b19coupe)
ABS code #16 is the right rear wheel speed sensor. Check the wiring to the speed sensor and check the teeth on the little gear at the right rear wheel. The sensor itself may be the problem. Seen a couple of bad sensors before.
Old Nov 25, 2002 | 11:04 AM
stRtypR25's Avatar
how did you find that out? is it in the helms manual?
Old Nov 25, 2002 | 11:07 AM
Hunter's Avatar
i had my abs light throw a code 81 a few weeks ago, which is a bad abs unit. well... i reset it and it didn't come back for a while. then it did it again, i reset it, and it hasn't done it again yet. any ideas what that might be from?
Old Nov 25, 2002 | 11:17 AM
iH8RICERZ's Avatar
Default Re: flashing abs light (Hunter)
my abs light comes on and off when i take turns hard.....i have no clue why......ever since i installed my z speed rear lower tie bar, i think it has something to do w/ that.....not sure
Old Nov 25, 2002 | 01:04 PM
Warren's Avatar
Wrong-Way Wang
I was up to my fuggin ears in ABS and other electrical codes. All turned out to be related to a bad alternator.
Warren
Old Nov 25, 2002 | 07:04 PM
b19coupe's Avatar
A bad connection or you may actually have a bad ABS control unit.
Old Nov 26, 2002 | 08:31 AM
what exactally does this speed sensor do? does it determine how to apply the abs, depending on the speed you are traveling?
Old Nov 26, 2002 | 09:19 AM
b19coupe's Avatar
ABS unit monitors wheel speed sensors to determine when to activate ABS control solenoids.
shortlid
Mar 15, 2006 05:04 PM
HOOKSH
Feb 11, 2005 05:55 AM
Ill
Nov 23, 2003 09:51 PM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
