LS pistons/B16 rods?
Old Nov 23, 2002 | 10:46 PM
Goldfingiz's Avatar
Default LS pistons/B16 rods?
Hey guys I am going to put LS pistons in my B16. Since B16 rods are shorter, I'm going to have to use them with the LS pistons. Do I have to take the pistons/rods to a machine shop and have them do it, or is there a way to do it myself? Not quite sure what the process is...
Any, and all help is very much appreciated.
Thanks,
Goldfingiz
Old Nov 23, 2002 | 11:35 PM
-16V-'s Avatar
Default Re: LS pistons/B16 rods? (Goldfingiz)
what are you trying to get out of this setup?
Old Nov 24, 2002 | 12:48 AM
Kamin's Avatar
Default Re: LS pistons/B16 rods? (1991_jdm_sleeper)
seriously
why are you doing this?
the ONLY thing it would be good for is some form of forced induction
your compression ration is gonna drop to about 8.5:1 from 10.2:1
[Modified by KAMiN, 1:48 AM 11/24/2002]
Old Nov 24, 2002 | 08:55 AM
Phaze2 Mike's Avatar
Default Re: LS pistons/B16 rods? (KAMiN)
Exactly, hes turbo. The 8.58:1 ratio this combo draws is nice for FI, but is it ok to use the b16 rods with LS pistons? Will there be an R/S problems.
Old Nov 24, 2002 | 03:52 PM
Goldfingiz's Avatar
My car is turbo, and I need low compression...so back to my original question, anyone know how much this will run and what the process is?
Thanks,
Goldfingiz
Old Nov 24, 2002 | 04:42 PM
b19coupe's Avatar
I would recommend forged custom pistons for that setup. Cast pistons are not as reliable for forced induction applications.
Colin's Avatar
the pistons will fit perfectly on the rods, no modifications needed. although a machine shop will have to use their press to remove the old pistons and put the new ones on.
the oem pistons aren't going to be as good for your turbo setup as some aftermarket ones would, but depending on application and how much boost the motor will be seeing...it probably won't make enough of a difference to matter.
you won't have any r/s problems. it will stay the same.
jhammond_82
Jul 15, 2009 04:44 PM
InTheLBC20
Jan 20, 2009 07:02 PM
the DA in HONDA
Mar 7, 2005 08:59 PM
hybridpatient95
Feb 9, 2005 04:45 PM
specie
Oct 13, 2003 11:34 PM
