bogging..
Old Nov 23, 2002 | 10:48 AM
hatchback's Avatar
Default bogging..
I am having problems with bogging. When in first gear as soon as the clutch engages my car will bog a little bit before taking off. Then I will shift into second and it will bog again.
Any ideas?
D16Z6 stock, 5th gen hatchback.
[Modified by hatchback, 7:49 PM 11/23/2002]
Old Nov 23, 2002 | 11:04 AM
Hammett's Avatar
Default Re: bogging.. (hatchback)
at what rpm do you take off and shift? Try releasing the clutch nice and smooth.
Old Nov 23, 2002 | 11:06 AM
hatchback's Avatar
Default Re: bogging.. (Hammett)
I release at 2000k, I thought that was the problem so I tried shifting at diff rpm ranges and I am still having the bogging. I know it cant be my driving..
I also got a brand new clutch (had it about a month now) so it cant be the clutch.
Any other suggestions?
Old Nov 23, 2002 | 11:16 AM
Hammett's Avatar
Im wondering if its the motor mounts? Im not sure though. any other input?
Old Nov 23, 2002 | 12:12 PM
hatchback's Avatar
I was thinking maybe my spark plugs and wires?
Old Nov 23, 2002 | 01:34 PM
.Beaver's Avatar
Bloody Beaver
I would make sure everything's tuned up- some injector cleaner, plugs, clean/ replace air filter, etc...
also could you be running rich or lean?
Old Nov 24, 2002 | 12:52 AM
hatchback's Avatar
Default Re: bogging.. (Evil Civic)
Thanks, I think I will definately try replacing all of the little stuff first.
What would I have to do if I was running too rich or too lean to solve the problem?
Old Nov 24, 2002 | 01:15 PM
hatchback's Avatar
bump
Old Nov 24, 2002 | 01:32 PM
deftones0817's Avatar
couldnt flywheel be glazed or something...sorry just throwing out some suggestions...is clutch just not engaging right away?
DEF
Old Nov 24, 2002 | 01:34 PM
.Beaver's Avatar
Bloody Beaver
I was running very rich, so I bought an Apex V-AFC, and had it tuned on a dyno so everything's all good now.
Old Nov 24, 2002 | 01:41 PM
hatchback's Avatar
Default Re: bogging.. (deftones0817)
DEF
The clutch is enguaging, its just there is no kick after wards.. it feels like a loss of power, (bogs) and then it takes off.
Old Nov 24, 2002 | 03:00 PM
TheIntegraGuy's Avatar
Could be alot of things...Bad o2 sensor (limp mode)...bad spark plug wires, bad, cap/rotor, bad spark plugs....bad fuel pump, dirty injectors, clogged fuel filter, clogged FPR....clogged fuel lines...out of all of that, I'm guessing it's either a bad coils, or bad spark plugs...
Old Nov 24, 2002 | 03:01 PM
hatchback's Avatar
Default Re: bogging.. (Esone3)
Thanks for the imput, I'll start checking.
shaylude
Sep 1, 2010 08:58 AM
FRKWOO
Jan 14, 2009 07:00 AM
B18cHatch4u
12
Oct 1, 2006 08:01 AM
BLACK97EKCOUPE
Jun 24, 2004 01:51 AM
Suave99
Apr 25, 2003 08:13 PM
