wheele shimmy at around 60 mph
Old Nov 22, 2002 | 01:30 PM
Hans's Avatar
Default wheele shimmy at around 60 mph
and idea waht could cause this?
Old Nov 22, 2002 | 01:58 PM
sauceman's Avatar
Default Re: wheele shimmy at around 60 mph (Hans)
check out if your wheels are well bolted.
Old Nov 22, 2002 | 07:27 PM
Chiovnidca's Avatar
Have you had your tires balanced?
Old Nov 22, 2002 | 09:24 PM
WhoNeedsVtec's Avatar
Default Re: wheele shimmy at around 60 mph (Chiovnidca)
Old Nov 23, 2002 | 12:18 AM
CD8's Avatar
CD8
Default Re: wheele shimmy at around 60 mph (WhoNeedsVtec)
yes and it still does it, except mine is at 64-68mph.... i know it will stop when i get new rubber. damn -camber
Old Nov 23, 2002 | 12:21 AM
Accord94DX's Avatar
Default Re: wheele shimmy at around 60 mph (vtecISscreaminLIKEyoMOMMA)
does it only do it under acceleration/braking? or all the time?
Old Nov 23, 2002 | 12:56 AM
CD8's Avatar
CD8
Default Re: wheele shimmy at around 60 mph (Accord94DX)
all tha time
Old Nov 23, 2002 | 04:11 AM
UseR's Avatar
I have that same problem. Except I haven't bled the brakes yet. Try that.
Old Nov 23, 2002 | 04:37 AM
Hippie's Avatar
Everybody has pretty much covered the 1st thing to check, wheel balance. It is also possible you have a bent rim, a broken belt in a tire or a tie rod end going bad. Haven't had my 1st cup of coffee yet so I'll stop there. Better get it checked out soon. That broken belt or bad tie rod end could cause you to lose control if they get worse.
Old Nov 23, 2002 | 07:56 AM
Gen4-5Door's Avatar
Default Re: wheele shimmy at around 60 mph (Hippie)
Rotate the tires and see if it changes. If it does, its one of the rear tires or wheels. If it doesn't, it could be an axle, bearing or even transmission. Good luck.
BryanM.
Sep 2, 2014 05:13 PM
Telecatster
Aug 27, 2013 11:28 AM
Christofurr
Aug 13, 2009 11:35 AM
Ed 341
Aug 14, 2006 04:02 PM
al@n
Apr 16, 2004 03:10 PM
