want to try and post an engine pic
car setup:
1997 turbocharged Integra Type R
Engine:
-Golden Eagle sleeves
-JE 9:0 pistons
-Crower rods
-ARP head studs
Cylinder head:
-stock valve train,ported,polished,and port matched
Transmission:
-stock except for clutch
Clutch:
-ACT Extreme pressure plate with six puck disc
Fuel system:
-Venom 100gph pump
-6an line
-AEM fuel filter & rail
-SX regulator
-Rc 720cc injectors
Fuel managment:
-Apexi Power FC
Exhaust:
-custom 3” down pipe
-custom 3” piping
-two Dynomax race magnum mufflers and one Apexi N1 muffler
Turbo:
-custom kit including:
-custom manifold
-t3 high flow turbine with .63a/r housing
60-1 compressor with t04e housing
-Tial 40mm wastegate
-2.5” piping to Apexi GTR intercooler
-3” piping to throttle body
-Greddy typeR Blow-Off valve
Ignition:
-MSD 6AL with 2 step
Best ET:11.86 Best MPH:121
Engine:
-JE 9:0 pistons
-Crower rods
-ARP head studs
Cylinder head:
Transmission:
Clutch:
Fuel system:
-Venom 100gph pump
-6an line
-SX regulator
-Rc 720cc injectors
Fuel managment:
-Apexi Power FC
Exhaust:
-custom 3” piping
Turbo:
-custom manifold
Ignition:
on those runs i was running about 20 lbs.that is about 3 lbs less than on the dyno.i use 118 on the track and can run 25+ lbs.on the street,i use 93 octane and 15 lbs of boost,sometimes 18 if i have to.the car made 310whp at 15 lbs and 410 at 19.
as far as axles go,i am using gck axles from advanced auto parts.they are incredible.i have been through about 5 sets of other axles and these are holding up great!(knock on wood)
boostedK20a2
Northern California (Sales)
69
May 13, 2007 10:09 PM
Rollex
28
Jul 2, 2004 07:57 PM
mntdewred
Apr 15, 2004 04:40 PM
