Rear Disk conversion (searched)
Hey guys I did a search all I found was somebody selling rear disk brakes ... what is required to do a rear disk conversion on a gen5 HB, I Do not want to do a 5 lug conversion so from what I have found GSR brakes will work ... what else is involved ? thanks for the help guys !
any 5gen rear disc brake or 94 up Integ rear disc brake setup will fit on your civic. get the whole trailing arm assembly. use your links that bolt to the trailing arm. your exsisting master cylinder will work unless you plan on using the front brakes from a civic ex or integra then you will need to use the master cylinder from the civic ex or integ. I installed the rear disc setup from an integ on my 4dr civic. it was a direct bolt on. I also have a big brake kit from FASTBRAKES.COM on both the front and rear. I am using the calipers from an integra up front and had to use the master cylinder from a civic ex. I've run this setup for the past year and a half and the whole setup works well.
asianman139608
Oct 26, 2009 07:21 AM
lastlude2k1se
10
Jan 17, 2003 12:19 PM
