Rear disc brake conversion.
Former Moderator
Re: Rear disc brake conversion. (lastlude2k1se)
If you want the car to stop better then do the rear discs LAST.
Rear discs alone won't help you car stop any better for ****.
I recommend doing the Integra front brakes forst with either a 1991 Civic EX 4-door master cylinder or a 1994-1995 Integra RS only booster and master cylinder combo.
My fiancee' has a 1992 Civic Si with 4-wheel discs and it doesn't stop nearly as good as my pal's 1993 Dx hatch with GS-R front brakes with RS booster and m/c and stock rear drums.
Former Moderator
Oh and for any parts call:
1-800-962-8922
Import Auto Salvage.
Ask for Larry Jr. or Randy. Tell them Tom from Georgia sent you.
They'll have front and rear discs and all of the other Integra brake stuff you'll need if you must go 4-wheel discs.
Don't get me wrong - I have all 4 cornmers of GS-R brakes, but I'd never do rear discs with stock Civic-sized front brakes.
1-800-962-8922
Re: Rear disc brake conversion. (B18C5-EH2)
Re: Rear disc brake conversion. (ejprimo)
tom, have you found out which combo is better? the RS mc and booster or the 91 ex 4-door mc and stock booster?
My fiancee' has a 1992 Civic Si with 4-wheel discs and it doesn't stop nearly as good as my pal's 1993 Dx hatch with GS-R front brakes with RS booster and m/c and stock rear discs.
I got my rear setup from Import Auto Salvage for $275+shipping. Came with all cables, and prop valve. I didn't need the MC/booster (EX has same ones as SI). Also don't forget to add money for brake fluid, new rear rotors and pads, and possibly SS lines.
Former Moderator
Re: Rear disc brake conversion. (kommon_sense)
Interesting, but to shed a little more light on this, the GSR has larger front calipers than the EX/SI.
Rear discs with stock-sized Civic fronts aren't worth a **** when compared to Integra front brakes with a bigger m/c and booster even if the car with Teg fronts still has stock drums in the rear.
eg8ynot
11-06-2008 04:43 PM
Stryker908
11-21-2002 06:09 PM
