Car won't start...Help...
The reason why the car won't start is because there's no fuel going into the engine. The fuel pump works, and it's sending fuel through the fuel filter ( I just replaced the filter two days ago ) and it's going to the FPR, but not going through it. I know it's going through because I took off the fuel line to the FPR and turned it to the "on" position and fuel comes out. But when I put it to the FPR, it doesn't want to go through. I replaced the FPR beause I thought it was clogged, but the new one did the same thing. No fuel going through. Injecotrs are working. I pulled out the whole rail including injectors inside, and NOTHING. I'm not sure what could be wrong. Maybe the fuel pump is dead? If it's dead, will it sill work? I hear it buzzing so I know it's on..and fuel IS going through the filter so it's working rght? I'm not too sure....but can you please help me? Thanks.
Cliff notes...Fuel pump is working. No fuel is going through the FPR/rail. Car won't start.
blinger
Sep 1, 2007 10:35 PM
TheIntegraGuy
18
Nov 22, 2002 05:53 PM
