magnetic drain plug w/ shavings
Old Nov 19, 2002 | 04:06 PM
SloEG's Avatar
Default magnetic drain plug w/ shavings
Can someone post the pic of the drain plug that has bunch of metal shavings on it. Thanks!
Old Nov 19, 2002 | 04:11 PM
Hooch'n's Avatar
Default Re: magnetic drain plug w/ shavings (SloEG)
Their should be very small shavings on the magnetic plug.....however, I would be worried if you see large shavings in your oil.....I am sure what you are seeing is normal.....Do a search, their have been a couple of pics of both the oil and tranny plugs.
Old Nov 19, 2002 | 04:12 PM
SloEG's Avatar
Default Re: magnetic drain plug w/ shavings (Hooch at 8400-RPM)
Haha, I just want that one pic that someone posted, had a lot of shavings on it. I tried the search and couldn't come across it.
Old Nov 29, 2002 | 01:33 PM
ragejed's Avatar
When i changed my oil, it I pulled out a weird piece about 1/16 of an inch long...i was scared.. plus alot of fine shavings and powder
vannak_5415
Oct 6, 2008 05:34 PM
SPEEDCORE
Aug 5, 2003 08:05 PM
King Tut33
May 14, 2003 04:31 PM
94dxt
Apr 21, 2003 03:37 PM
