Going Into Gears Problem
Old Apr 4, 2025 | 07:13 PM
eekae's Avatar
Default Going Into Gears Problem
Some background info before we get started is I have an EJ8 that has a y7 swap and also manual swap from previous owner. For around the past two months I’ve been having random occurrences where my car stops wanting to shift into gears or is very hard to force it into gears with the shift ****. Usually to “fix” this issue temporarily I noticed if I turn off the car and tighten the terminal bolts the transmission goes back to shifting like butter. If I’m at a red light and this happens I have to turn off the car put it into second gear, turn the car back on and then continue until I’m able to tighten the bolts. I’ve tried replacing the terminals and even alternator but either way it does nothing to help. If I tighten the bolts tight I usually don’t have to tighten them for a few days but it’s still a recurring issue. Any tips or help? Any info is much appreciated thanks for your time
SCMFOX
Jul 16, 2018 04:06 PM
jimgade
Transmission & Drivetrain
Feb 16, 2015 09:40 AM
NoWorry's
Apr 5, 2013 03:45 PM
car_forum_user
Mar 24, 2013 05:54 AM
Ivan
Feb 9, 2006 12:22 PM
