No spark turbo civic
Hey so I’ve got a 94 civic d15b7-t. Bassicly what’s been happening is randomly while driving I’ll get a cel and it bassicly looses all power until I cut the car off and start it again, boom back to normal no cel. Yesterday the car died but wouldn’t start again. Fuel pressure is good, no codes but a solid cel, no boost leaks no vaccum leaks just 0 spark coming from the coils. If it was a distributor I’d think I’d have a code 15 or something for the icm but it has nothing showing up when I jump the clip. How can I test the ecu? It’s a chipped and tuned p05(I know I’m not suppose to run that lmao but it works temporarily)
I can get access to a p2E ecu from a 97 dx to test it if that’ll work.
Check grounds and make sure all are clean and tight. Next, test with a "known good" ECU to start the car. If it fires right up, it is likely that the ECU is the problem. To be sure, immediately unplug the "known good" ECU and re-connect the chipped ECU and crank the car. If it fails to start and/or doesn't run, your problem is the ECU.
If your running a stock ECU make sure the Injectors, Map sensor are stock,
If you do have aftermarket Injectors and 3 or 4 bar map sensor, make sure those are selected and saved in the ECU parameters.
97_ek_coupe
Aug 16, 2013 05:44 PM
BigGonz
23
Aug 2, 2011 03:55 PM
khmboostedeh2
Apr 1, 2006 07:09 AM
