Violent jerking in 1st and 2nd gear / 98 HX
Anyone know what would be causing violent jerking in first and second gears? I got a salvage title 98 hx I picked up and have done about every maintenence item and repair I can think of, and it drove fantastic for the last couple weeks, but last night on my commute I downshift like normal and it started. This morning tested it out and this is what I'm getting:
Smooth idle
Jerks almost immediately in 1st
Smooth in 2nd until you apply enough gas for accelerating, then the same jerking
Rest of the gears run fine
Thought about it being gas but filter is new, tank of fuel is new from a Chevron with a bottle of Redline SI-1, and higher gears work fine so probably not the pump?
Any thoughts appreciated
My maintenence included: plugs, wires, cap, rotor, fuel filter, multiple oil changes, valve cover gasket, pads & rotors, brake flush & bleed, cv axles, transmission flush, clutch, clutch bleed, coilovers to replace bad shocks
Smooth idle
forevermemorabl
19
Sep 25, 2013 10:54 AM
muddmonky
Apr 11, 2013 12:10 PM
zenon8890
Nov 16, 2012 02:33 AM
Turbotype
29
Sep 15, 2010 07:53 PM
Low_bias
Apr 26, 2002 07:53 PM
