ABS modulator bleed procedure?
1994 honda accord DX (with antilock brake system)
What is the proper way to bleed the modulator? There is a bleed valve/screw on the top of the module itself. I am replacing every line in the vehicle and air will get into the module so I need to know proper bleed procedure. I noticed if I remove the signal wire (but keep ground connected) on the brake fluid reservoir level sensor, the abs pump cycles with KOEO
Yes ineed, thankyou so much for the reply! I am running all new brake lines and thought while I am at it might as well run the master cyl to modulator lines but I know I am gonna get air into the modulator, thanks so much!
