99 Civic y7 to y8 intake swap problems
I have a 99 civic with a d16y7 engine. Made this swap to the d16y8 intake manifold a few months ago, but there's only one problem: the idle still fluctuates up and down a little bit.
A few things to consider:
Can someone help me please? I can attach a video later today
- I use the hondash bluetooth thingy to check all the parameters
- It's an automatic intake installed on a manual civic, which means that I had to block the holes on the back of the manifold
- When the car comes to a complete stop, the idle fluctuates a few times (3-4 times) going to 1500rpms and then back to 1000rpms
- I'm using the y7 throttle body, which has the IACV at the bottom
- IACV seems to be fine, running at a duty cycle of 3% when idling (it goes up to 20% when I rev then back to 3% when I stop revving)
- MAP sensor seems to be fine also, runs at 0.85v when idling (it goes up to 2.4v when I rev then back to 0.85v when I stop revving)
- TPS sensor is fine, stays at around 0.5v when idling
- Intake pressure sits around 285mBar
- Checked for gasket leaks and couldn't fine one
- All hoses are tight
I had the same issue with mine. I needed to adjust the throttle cable, because it was holding the throttle blade open. With everything set right my throttle position reads about 9.5% at idle
latinheat4ya
13
Mar 16, 2008 10:45 AM
Leb_CRX
18
Apr 20, 2005 07:21 PM
Sinister_Civic
Nov 22, 2004 05:54 PM
1.8Tities
Mar 4, 2003 03:46 PM
