Trying to hook up an MSD 6AL some questions
Old Nov 18, 2002 | 06:43 PM
underpressure02's Avatar
Default Trying to hook up an MSD 6AL some questions
I have a 95 LS Motor. The kid I bought the car from gave me a new 6AL with two step. I was reading over how to install it tonight and I have a few questions.
Does this motor have an internal coil?
I do not see an external coil so I am assuming it does.
Do I need a Blaster coil and power cap to hook this up? Or can I just use my stock Distributor cap and coil?
The plug wires on the car say Triple Magnitic Core are these safe to use?
TIA
Old Nov 19, 2002 | 05:18 AM
Default Re: Trying to hook up an MSD 6AL some questions (underpressure (wtbimport))
ttt
Old Nov 19, 2002 | 06:49 AM
EG-cellent's Avatar
your motor has an internal coil. you can get an blaster coil and use a msd cap if you want to but you can also use the factory coil and cap. it just depends on what you want to do.
Old Nov 19, 2002 | 07:50 AM
Default Re: Trying to hook up an MSD 6AL some questions (EG-cellent)
Will it make a difference if I use the stock cap? My understanding is all I have to do is drill a hole in that cap to connect the wires to the coil. Is this correct?
Old Nov 19, 2002 | 08:06 AM
twitchm80's Avatar
not really save your money, just use the stock coil/ cap pending they are still in good condition, and YES just wire up the internal coil and drill a small hole and connect the wires
Old Nov 19, 2002 | 09:14 AM
Default Re: Trying to hook up an MSD 6AL some questions (twitchm80)
In the instructions it was saying about drilling a few small holes in the cap to let air in to eliminate arcing. Did you do this? I do not feel comfortable drilling extra holes in my cap for fear of speeding up the process of rust.
Old Nov 20, 2002 | 06:36 AM
EG-cellent's Avatar
no just drill one hole and then silicon it after the wires are ran through.
honda_SiRII94
Apr 9, 2007 08:14 AM
newfie24
Apr 14, 2006 07:36 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
94SHOWLS
Feb 16, 2005 08:00 PM
