msd cap
Old Feb 16, 2005 | 11:54 AM
94SHOWLS's Avatar
Default msd cap
anyone know what has 2 be modified 4 a msd pro cap??
Old Feb 16, 2005 | 12:04 PM
importdude2000's Avatar
Default Re: msd cap (94SHOWLS)
use use an external coil?
drill a hole for wires to come out of the distruabator thats all
also since u have a 94ls i assume
just get a 92-96 preludevtec exteranl coil cap
it works wonders
Old Feb 16, 2005 | 04:52 PM
SpoonFull's Avatar
yea i got a question about the modified dist. cap for my gsr. what kinda of external "Blaster Coil" would i need to make the dist. cap work. thanks
Old Feb 16, 2005 | 05:09 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (SpoonFull)
Unless you have some high revving heavily modified engine, stay away from msd external coilpacks. There was one on my car when i bought it and all it's given me is **** so far.
Old Feb 16, 2005 | 05:16 PM
6m and going no **** from a coil
besides its liek 30 bucks for a new one
Old Feb 16, 2005 | 06:07 PM
Racermech's Avatar
Default Re: (importdude2000)
Why not just order ther crane cap that is made for the B series engine, and has the hole for the external coil. I know summit has them
Old Feb 16, 2005 | 06:26 PM
l2Y4N's Avatar
like mentioned you just have to drill a small hole for two wires, its easy. and theres nothin wrong using an external coil on a non-heavliy modified car. i have mine (msd) because i found it cheaper than oem when my old one went out on me.
Old Feb 16, 2005 | 07:14 PM
GTWITIT's Avatar
Default Re: msd cap (integraTracer)
i have a blaster coil on my car but i alson have a complete 6al MSD box, i tried it with stock external coins and the msd burned them up in about 3 weeks, I brought a blaster 3 and its been in 4 almost a year now with no problems
Old Feb 16, 2005 | 07:55 PM
SpoonFull's Avatar
the reason why im asking is because when i bought it i thought it was a direct bolt on. what does a coil do? where do i drill the holes?
Old Feb 16, 2005 | 08:00 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFull &raquo;</TD></TR><TR><TD CLASS="quote">the reason why im asking is because when i bought it i thought it was a direct bolt on. what does a coil do? where do i drill the holes?</TD></TR></TABLE>
The coil won't be making you hp, pretty much it just helps stop misfire at high rpms. It's easiest to just get a MSD cap, You also have to take out the coil inside your stock distributor and have two wires from the pack go inside your distributor.
For a stock and near stock engine, you won't find any need for a MSD external coil pack, you'll more then likely have more things to worry about with it.
honda_SiRII94
Apr 9, 2007 08:14 AM
SpoolnByYou
Mar 25, 2006 09:10 AM
