Trying to hook up an MSD 6AL some questions
I have a 95 LS Motor. The kid I bought the car from gave me a new 6AL with two step. I was reading over how to install it tonight and I have a few questions.
Does this motor have an internal coil?
I do not see an external coil so I am assuming it does.
Do I need a Blaster coil and power cap to hook this up? Or can I just use my stock Distributor cap and coil?
The plug wires on the car say Triple Magnitic Core are these safe to use?
TIA
TIA
Re: Trying to hook up an MSD 6AL some questions (underpressure (wtbimport))
your motor has an internal coil. you can get an blaster coil and use a msd cap if you want to but you can also use the factory coil and cap. it just depends on what you want to do.
Re: Trying to hook up an MSD 6AL some questions (EG-cellent)
Will it make a difference if I use the stock cap? My understanding is all I have to do is drill a hole in that cap to connect the wires to the coil. Is this correct?
Re: Trying to hook up an MSD 6AL some questions (twitchm80)
In the instructions it was saying about drilling a few small holes in the cap to let air in to eliminate arcing. Did you do this? I do not feel comfortable drilling extra holes in my cap for fear of speeding up the process of rust.
