Idle issues with eg B16a motor
Old Apr 6, 2023 | 08:06 PM
Spaz253's Avatar
Default Idle issues with eg B16a motor
Ok I'll start from the beginning we replaced a IAC valve hose a couple weeks back because it was causing a vacuum leak on one side and leaking from the other so we replaced it, now we can drive the car 15 to 20 minutes and then the RPMs drop and the car wants to shut off the last couple times the car actually shut off. not sure what it could be a couple of people have told me maybe we got air in the line when we swapped out the hoses. I talked to a mechanic he said it might be the distributor.? any help would be appreciated thank you
Old Apr 6, 2023 | 10:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Idle issues with eg B16a motor
I don't believe the distributor is your issue... trying a known good one will certainly rule this out, but this isn't the first thing I would look at to solve your issue.
Old Apr 7, 2023 | 03:46 AM
Chance EG's Avatar
More than likely it's still something with the IACV, or another vacuum leak/blockage you have somewhere else in the system (like the FITV if you still have it installed).
FITV wouldn't necessarliy be my first guess as that should be most active on a cold start, not when the car is warm and driving. Have you cleaned the IACV screen? There's a mesh screen on it, if you've never cleaned it, pop it off the car and shoot it with some carb/brake cleaner and get it all cleared up.
The car should idle at about ~900-950RPM.
Old Apr 7, 2023 | 11:24 AM
Spaz253's Avatar
yes we popped it and cleaned mesh screen it looked clean tho we replaced one of the shorter hoses that goes from iacv to under air intake... yea car drives fine for 15 to 20 minutes then starts acting up
Old Apr 7, 2023 | 11:25 AM
Spaz253's Avatar
u still think it could be air in coolant line? Were gunna try and burp in later.
Old Apr 7, 2023 | 07:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the "hunting idle" comes and goes... it is air trapped in the cooling system. If the problem begins after fifteen or twenty minutes and never stops after this until you turn the engine off... it is something else.
Old Apr 7, 2023 | 08:47 PM
Spaz253's Avatar
usually when it starts doing that we're close to the house so we don't know if it stops doing it, we usually pull in and shut it off. If it is air in line how long will it act like that before going back to normal? If it don't stop till we shut it off what else could it be?
Old Apr 8, 2023 | 08:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Think of the air pocket like the Moon orbiting the Earth. You can only see the Moon when it is in the right place... not all of the time. When the air bubble is just in the right place, the engine begins to "idle hunt". Once it passes this point, it must move through the cooling system until it comes back around to the same location where the "hunting" begins. So, once it happens, drive some more. Go around the block a few times... the starting and stopping moves air through the system. Idling doesn't move much fluid... so the problem will stay longer in this condition.
JustEFit
Jul 22, 2013 06:43 AM
jayeghatch
Aug 28, 2012 03:59 PM
jayshf
Sep 17, 2009 08:10 PM
RaYnE
Aug 11, 2006 04:36 PM
ITR1071
May 25, 2002 01:05 PM
