Transmission swap
Old Feb 5, 2023 | 02:12 PM
civiclover97's Avatar
Default Transmission swap
So I have a 97 Honda civic non vtec witch has been swapped to manual transmission but still have the automatic wiring harness and ecu and is stuck in limp mode is there a way around getting a manual ecu?!?
Old Feb 5, 2023 | 03:32 PM
Ryanthegreat1's Avatar
Default Re: Transmission swap
Put the automatic back?
Old Feb 6, 2023 | 08:04 AM
Sic_DA_Nine's Avatar
When i initially did my 5 speed swap on my old 95 civic, i didnt change my wire harness or ecu and it was driving fine. it did throw a CEL for auto trans tho.
are you throwing any codes?
Old Feb 6, 2023 | 08:50 AM
hondamark35's Avatar
The short answer: no, you need a manual ECU.
The easiest option would be to find a manual ECU for a '96-'98 LX or DX. Get the engine harness with it if possible to make it even easier.
OBD1 is a little more forgiving than the OBD2a that the OP is dealing with. It's possible and even kind of easy to convert the factory ECU from an OBD1 Civic from auto to manual. As far as I know this is practically impossible with the OBD2 ECU.
Kamilsamek
Jul 25, 2018 05:58 AM
Lildj2983
Oct 30, 2014 10:54 AM
E M Wynne
Engine Management and Tuning
Mar 26, 2013 05:33 AM
tealsvteceg
May 25, 2008 04:18 PM
lunarcry
Mar 31, 2004 12:03 PM
