Weird starting problem
Old Dec 8, 2022 | 02:57 PM
Jaemasin's Avatar
Default 92' Civic Hatch Starting Issue
I'll start by saying this problem occured when I tried installing a kill switch to my ignition wire then my ignition fuse blew, since then I have replaced the old ignition with a JDI push to start in the hopes of it maybe fixing the problem but it didn't. Now when my key is in the ignition and I turn it, it turns on all the electronics, fuel pump ect. on but the car doesnt crank, click nothing not a single sound. Currently to start my car I unplugged the starter wire and plugged in my own wire running to a button that has another wire running to the battery to give it that spark to start. Could this be a wire harness issue or something to do with ​the starter?
Old Dec 9, 2022 | 07:33 AM
Jaemasin's Avatar
Default Re: Weird starting problem
I assume this has no replies because people doht know the answer?
Old Dec 9, 2022 | 11:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
No replies because unfortunately this is a mostly dead forum.
I see you have a 92 Civic...what trim level? Auto or manual transmission? If auto, there is a switch at the shifter that will not allow the starter to get power unless the shifter is in park. If manual, there is a switch on the clutch pedal that goes to a under-dash relay, which must be engaged for the starter to get power. You may have damaged one of these switches or relays when you blew the ignition fuse.
Do you have a copy of the Factory Service Manual made by Helm, Inc.? If not, you should get a copy.
Old Dec 9, 2022 | 01:33 PM
Jaemasin's Avatar
The trim is CX it has the original d15b8 motor and it is manual my fuses and relays are all good, and that switch your talking about is it the one where you gotta push the clutch in for it to start?
Old Dec 9, 2022 | 04:16 PM
DaX's Avatar
DaX
Loved
Community Favorite
Originally Posted by Jaemasin
The trim is CX it has the original d15b8 motor and it is manual my fuses and relays are all good, and that switch your talking about is it the one where you gotta push the clutch in for it to start?​​​​​​
yes. The switch is probably fine, I would be more concerned with the relay that the switch controls.
Old Dec 9, 2022 | 04:53 PM
Jaemasin's Avatar
I Don't think it's the switch because I made it where I dont have to push the clutch to start the car and I've had it like this since I've got the car and didn't have problems till my kill switch grounded out but I'll recheck the relays if it's not relay or the switch do you think it could be something deeper?
Old Dec 9, 2022 | 05:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
No. The starting circuit in this vintage Civic is really pretty simple.
Old Apr 22, 2023 | 10:23 AM
James Albert's Avatar
Did this get resolved? I have some weird issue which seems similar
poison
Oct 21, 2016 02:26 PM
b16rex_02
Feb 22, 2014 04:42 AM
b16rex_02
Feb 24, 2009 11:59 PM
b20vtecEK
Apr 7, 2005 07:28 AM
