How does ECU calculate mixture from start up
Old Nov 30, 2022 | 03:15 PM
Glennb1's Avatar
Default How does ECU calculate mixture from start up
Hey guys,
I have a 98 Ek D16Y4 civic, and is running rich. This is the model without o2 sensor, so i installed a set of headers and an o2 and gauge and now i can see how bad it is.
Motor has previously an old ladys car and after me doing 50,000k of driving it burnt a valve and pistons were covered in a thick carbon layer. Was also very sluggish. Been re rung, new valve etc.
Anyway i want to know how the ecu alters the mixture, I thought that the motor ran rich on start up and leaned out when the motor got to operating temperature.
Mine will start at about 13.7:1 for a minute , then slowly goes richer until the motor is warmed up and it will cruise at 11.7:1 and wot is about 10.7:1.
I have checked voltages on all the sensors , temp tps map and fuel pressure, they are all ok according to charts. both Timing belt and ignition is fine
On my second o2 sensor now and don't want it doing what it previously did.
Does anyone have any suggestions?
Cheers
Old Dec 1, 2022 | 07:41 AM
tennessee_eg's Avatar
Default Re: How does ECU calculate mixture from start up
Which ecu are you running? Stock injector and fuel pump?
Old Dec 1, 2022 | 09:15 AM
Glennb1's Avatar
Everything thing is stock from factory except for headers
Old Dec 1, 2022 | 05:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
D16Y4 isn't a north american motor. What market is your 98 civic? USDM and CDM both don't have any model in the 96-00 range that did not have an o2 sensor for fuel trim.
Old Dec 1, 2022 | 07:32 PM
Glennb1's Avatar
New Zealand and probably Australian market and more.my ECU is 37820-P2K-V01 and I searched that and found out.
https://nzhondas.com/topic/94901-p72-ecu-in-nzdm-ek-p2k-ecu-help-needed/
Old Dec 2, 2022 | 08:32 AM
Relic1's Avatar
NZ got all sorts of funky stuff like this.
check the intake manifold temperature sensor and engine coolant temperature sensors. if either other of those are giving the ECU the wrong data it will result in A/F's that are off as you describe.
Old Dec 2, 2022 | 02:55 PM
spAdam's Avatar
Loved
Community Favorite
^This. If there's any way to be connected to a scan tool and jiggle the plugs around while watching the values, you may be able to find your culprit.
Generally, when you cold start the ecu piles a bunch of extra fuel in to hit a richer target to help get it going and warm up faster. This number tapers down as coolant warms up. It also applies another post-start adder on top of that tapers down quickly after firing over a number of engine cycles. 13.7 ~= .93 lambda, that seems reasonable for a warmup mixture if not a touch lean. The rest is obviously stupid rich.
P2K ecu is the two-connector style, right? Should have had a one-wire O2 sensor, they also batch fire the injectors in pairs. Some other threads I look at real quick seems to think you should have a one-wire sensor on a '98 too: o2 sensor for d16y4 EK (ozhonda.com)
Is there a white wire in ecu-D20?
Old Dec 5, 2022 | 05:22 PM
Glennb1's Avatar
This **** model didn't come out of the factory with an O2 sensor .
my fuel starts, when engine is first turned on, at about 13.7:1 and slowly gets richer as it warms up to about 11.7.
It should be the other way round rich cold, leaner when up to temp?
I'll check the iat sensor values and do the wiggle thing on the other sensors.
Old Dec 5, 2022 | 05:24 PM
Glennb1's Avatar
This is what all the pistons were like when motor was stripped when it burnt a valve.
angelSIR-G
Dec 3, 2006 01:03 PM
dogfood
Oct 6, 2004 04:45 PM
Civic Hx-T
Apr 23, 2004 05:54 AM
Nick7
Sep 6, 2003 08:40 AM
89 CRX SI
Dec 7, 2002 06:25 AM
