Very bad vibration/shaking after 5 lug swap @80mph
Before doing my 5 lug swap the car was driving perfectly fine at any speed with a trashed suspension, humming wheel bearings, mismatched steelies with mismatched bald tires and a backyard tooth floss jack stand alignment and it drove straight as an arrow at any speed with no mechanical problems. Now it has a bad intermittent vibration that starts @60mph on the front passenger side and it gets so bad @80mph it feels like the whole front end is going to explode. The steering wheel feels like a vibrator and you can even see it in the dash. It also has a clunking sound when turning, a slight pull to both sides while going in and out of the gas and a slight pull while braking. Parts I got came off a RSX part out with way less miles. There’s zero play in the wheels or in the tie rods. Everything on the front end has been replaced from the lower control arms, both axles and up to the bc coilovers. Rides buttery smooth up until 60mph. It’s on factory RSX 16s with Goodyears all the way around. I highly doubt it’s a tire balance issue they’ve all been been weighted and it doesn’t look like any have fallen off. I also swapped the passenger side wheels with no affect. Any ideas?
Alex_C
Oct 10, 2008 08:29 AM
JokerTypeR
31
Mar 5, 2005 06:09 AM
