Alternator not charging battery
2004 civic lx 148k miles- Replaced battery and alternator. Alternator showing 12-14v at alternator post. Battery not seeing those same volts. Grounds all look good and wire doesnt appear to be nicked or damaged. Should be getting same voltage at T101, but not. What could be acting to pull down voltage? Also cant get obdii to connect.. maybe coincidence, but believe its part of same issue. Car runs well when battery fully charged.
i actually didnt know how to do a drop test, but i took the car after charging the battery to autozone and had them check the alternator (which was brand new). The guy with his tester immediately said- ooh.. bad voltage regulator.. so, thanks for the feedback- bad ‘rebuilt’ alrernator from Autozone… got a new one, installed and now maintains charge! Situation resolved!
ALLDAY-24
18
May 3, 2011 08:25 AM
BlowOff
Jun 11, 2002 07:08 PM
