Difference between YY ECUs and X5 ECUs
Old Jul 27, 2022 | 10:17 AM
JohnDM 1010's Avatar
Default Difference between YY ECUs and X5 ECUs
I want to know the difference to these because i am manual swapping my 04 Honda CRV and i have a 05 CRV parts car with the manual transmission and the manual ECU for the 05 has YY on it and the 04 manual ECUs have X5 on them i have look at them both and they have the same plugs but i want to know if the 05 ECU will work in the 04 that way i can know if i have to buy a 04 ECU or not.
Old Jul 27, 2022 | 12:17 PM
Ryanthegreat1's Avatar
Default Re: Difference between YY ECUs and X5 ECUs
In the US market the CR-V went to drive by wire in 2005. 2004 and 2005 are not compatible.
Old Aug 1, 2022 | 01:18 PM
Thank you i remember a bit after i made this post it's ok though i can sell the 05 ECU and use the money to buy a 04 manuel ECU.
Old Aug 1, 2022 | 02:32 PM
The automatic PCM will run the engine with the manual transmission but it will set the check engine light for the missing transmission.
Don't forget a new to you PCM will need to have the immobilizer programmed to your vehicle. Dealership, locksmith, or anyone with the proper tool can program this.
fryman
10
Mar 24, 2023 01:40 PM
sirb18a
May 26, 2013 09:13 PM
ramonjones16
Jul 27, 2009 12:13 AM
bubba cola
Jan 31, 2009 10:20 PM
