New Distributor still getting code 4 crankshaft sensor
Old Jul 16, 2022 | 10:34 AM
Chime999's Avatar
Default New Distributor still getting code 4 crankshaft sensor
Car has been in limp mode for a while. Had a error code for top dead centre sensor got a new distributer, fixed it, now im getting code 4(crankshaft sensor) which is inside the distributor. I did research and people said check the wiring to the ecu. In the pic below is it connecting to the ecu? Cause it looks a little burnt.
if so how would I test it using a multimeter
Old Jul 16, 2022 | 12:30 PM
ScarletOkami's Avatar
Default Re: New Distributor still getting code 4 crankshaft sensor
what year? and what engine? only then will we be able to help you, but i do have resources to share like this, also i highly reccomend picking up a voltimeter to see if you are actually getting current to the plug, or if its your wires/plugs
Old Jul 16, 2022 | 01:54 PM
Chime999's Avatar
91 accord lx
2.2L
I have a multimeter do I test it by putting the ends in the plug, wheres the negative and postive side in the plug
Old Jul 16, 2022 | 02:16 PM
should be similar to what GhostAccord said here
kirbyman
Oct 20, 2024 07:35 PM
aviator.sm
Engine Management and Tuning
Jul 26, 2018 12:10 PM
sc00te12d00d
Dec 11, 2003 09:01 AM
H22CIVIC
Jul 2, 2001 11:19 AM
