Boost leak test leaking from VC breather
Old Apr 8, 2022 | 06:30 AM
1mweeks's Avatar
Default Boost leak test leaking from VC breather
So today I decided to do a boost leak test on my D15B by attaching my adapter directly to the turbo intake and it would not pressurize at all. I mean, it all just poured directly out of the valve cover breather port which currently just has a filter on it. Is this normal?? I also later then attached the adapter directly to the throttle body and it seemed to pressurize as expected (despite a few leaky areas that I will have to look after). So being that when attached to the throttle body there is no leak, and when attached to the turbo there is a giant leak, leads me to believe the turbo is the failing area. But what could be causing this? Bad turbo seals? I'm a bit lost how the pressured air could be routed to the valve cover so effortlessly.
If it matters, the PCV valve (black box) has been removed as it routed to a sealed catch can which then exits to the intake piping. The car also had previously been blowing some smoke, so I did recently just replace the valve seals. Last compression check wasn't that long ago and everything checked out fine. Any thoughts? This really has me confused.
Old Apr 10, 2022 | 04:01 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Boost leak test leaking from VC breather
You answered your own question. A sealed catch can routed to the charge pipe is your link between turbo intake and the crankcase. Disconnect the catch can from the charge pipe, plug the hole in the charge pipe, and vent the crankcase (via the catch can) to atmosphere.
Old Apr 10, 2022 | 05:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
Beat me to it!
sleepercivic88
Apr 10, 2009 05:57 AM
94siludeturbo
Jun 26, 2006 02:07 PM
SoSlo
May 31, 2005 04:18 PM
BME1986
Apr 24, 2005 01:04 PM
Bongnak
Jan 7, 2003 04:44 AM
