How to seal unused ports on wastegate?
Old Feb 22, 2022 | 04:20 PM
ohisofly's Avatar
Default How to seal unused ports on wastegate?
I'm getting around to changing my wastegate, and I noticed that the wastegate plugs for the 1/8" NPT ports which won't be used have o-rings to seal instead of sealing by the NPT threads. I'm kind of sketched out by an o-ring sealing the unused ports on the wastegate considering how hot these things get and then adding boost pressure on top of that. I was always under the impression that NPT threads are sealed by the threads themself, but these plugs thread in very easily, and tightening them just squishes the o-rings.
This is regarding a VS racing wastegate, but I have a new genuine Tial wastegate for reference and it also has allen head 1/8" npt plugs for the unused ports. The only difference is that the Tial allen head plugs don't have o-rings, but they still don't seal by the threads and just bottom out if you thread them in the whole way. I can't imagine the plug would be airtight just bottoming it out considering the threads don't seal at all.
Is it ok to seal these plugs with o-rings, or maybe people use crush washers? The only option that makes sense to me would be to use a traditional npt plug that does actually seal by the threads (pictured in the background), but I figure there has to be a way people make it work with these allen head flush looking plugs that come with the wastegates.
Old Feb 23, 2022 | 02:40 AM
ls joker's Avatar
Loved
Default Re: How to seal unused ports on wastegate?
I have had my same tial mvs gate since 2009. On those fittings i teflon taped them before i put them it.
They prolly could be retapped lol. I didnt trust the oring on there aswell.
Old Feb 23, 2022 | 06:27 AM
Ryanthegreat1's Avatar
What about that aluminum crush washer in the picture? Can't find one of those to fit?
Old Feb 23, 2022 | 01:40 PM
ohisofly's Avatar
I was thinking about using the crush washers, but from the packaging it's pretty clear those were intended to be used with the banjo bolt fittings. In theory I assume that would work though
Old Feb 23, 2022 | 02:35 PM
I would find the crush washers. They don't deteriorate with heat like o-rings or thread sealant.
Old Feb 23, 2022 | 09:35 PM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Thats an orb port. ( o ring boss)
If its an mvr it should be water cooled and the o rings should be fine
Old Mar 1, 2022 | 08:24 AM
ohisofly's Avatar
Interesting, appreciate the heads up and yea it's an MVR (44mm). It appears that the wastegate ports are m10x1 threads and while 1/8" NPT fittings will fit, it'll mess up the threads. Apparently, they're close enough that you can use a 1/8" NPT tap to rethread it to NPT threads so I'll be giving that a shot.
Old Mar 1, 2022 | 01:49 PM
highschooler's Avatar
If it’s M10x1 threading, why not just buy a short bolt that is that threading, and put a washer (maybe a crush washer) on there, maybe with some sort of high temperature sealant?
I don’t know if I would want to re-tap it.
I’ve seen that the water cooling is optional on that wastegate. I have one, although I haven’t used it yet, but don’t plan on water cooling it. It isn’t required is it?
Old Mar 2, 2022 | 08:29 AM
ohisofly's Avatar
That's a good point, I guess I'm kind of worried how well the crush washer will keep it airtight under boost but I'm probably just overthinking things. Crush washers seem to work fine for sealing our oil pans, trannys, diffs, etc.
I don't plan on water cooling mine either and seems like it's just optional, more intended for setups like road race cars or engine bays with poor airflow. Someone correct me if I'm wrong, but it appears that you just leave those water ports open with nothing threaded into them if they're unused as it doesn't come with plugs for those. These are the water port to 4an fittings that come with the Tial wastegates
Old Mar 2, 2022 | 12:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
Right, leave the water ports open if unused. Can't remember if my gate has o-rings or not, but I used whatever came with the gate and haven't had an issue in 3+ years.
Old Mar 4, 2022 | 05:38 AM
TheShodan's Avatar
Moderator
Same after 10+ years. And I'm using the water cooling ports.
Old Apr 8, 2022 | 06:42 AM
1mweeks's Avatar
When I installed my turbo I had found a small holes drilled in to the intake manifold on the back where they had been hard to see. Not sure what their original purpose was, but they needed to be filled. Being that they were on the manifold and rounded, I tapped them out and threaded some short bolts in with o-rings to accommodate for the non-flat surface. They have held strong and never leaked since. That being said, being that you have a flat surface, I would go with a crush washer. Highly doubt they will ever leak out even under boost. Teflon tape or locktite to be sure.
elpiar
Sep 8, 2005 09:32 PM
Prelude91siT
Apr 13, 2004 12:46 PM
WEPN R
Mar 2, 2004 10:16 AM
RedTegLS
Nov 21, 2003 03:47 PM
AVATAR
Apr 21, 2003 11:04 AM
