650hp Turbo J32A2 - GTX4202R or GT3582R?
Which turbo would you go with?
The GTX4202R is rated for 525-1120hp and I'm looking to make about 650hp. The GT3582R is rated for 400-675hp. I want to spool as fast as possible and tune for lower to mid range torque.
With the GTX4204R I'm thinking room to grow so I can make 650-750-1000hp plus it wouldn't choke the motor out at higher rpm. At 650hp I'll be using about 58% of the turbo but would it spool fast enough and make good low end power?
With the GT3582R I'm thinking I will spool real fast and have a more streetable turbo but won't have room to grow or have a very high cfm flow at or near redline. At 650hp I'd be using about 96% of the turbo.
Found the TL build.
https://honda-tech.com/forums/forced...build-3184278/
I'm shooting for 650 flywheel hp. I think I'm going to go with the GTX4088R its a little smaller than the GTX4202R and is rated for 460-850hp. @ 650 flywheel hp I'd be using about 77% of the turbo. This still gives room to grow if I wanna make more power later on down the road, say bump it up to 800-850hp.
I'm thinking the GTX4088R will provide the low end torque I want and spool quickly, I want a grunting street machine, I'm also thinking it wont choke out the motor at higher rpm, say around 6,800-7,500 and will likely make peak hp near 7,000 so I should be good.
I'm thinking the GTX4202R would probably be a bit too big, likely wouldn't spool to quick or be very responsive below say 4,000rpm and would just block exhaust flow until it spooled plus it costs quite a bit more than the GTX4088R.
I know the GT3582R is likely way too small now that I think about it, I'd be using most of the turbo to make the 650hp and it would probably have no top end.
escape2me
Apr 20, 2004 12:49 PM
