Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Power steering leaks 2007 minivan
Old Dec 6, 2021 | 08:35 AM
sujitroy's Avatar
Default Power steering leaks 2007 minivan
I have a power steering fluid leak. right near the front of the car. it seems to be the return pipe to the reservoir. I changed the high pressure line a few months back. I can't figure out the route of the line. Fluid is dripping on the subframe and then dripping off the frame. I had the wheel off yesterday. Do i need to remove the plastic cover under the wheel arch to see where the hell that line is?
Sujit
Old Dec 6, 2021 | 03:57 PM
Chrisfrom1986's Avatar
Default Re: Power steering leaks 2007 minivan
https://www.hondaautomotiveparts.com...sis--p-s-lines
Old Dec 7, 2021 | 01:51 PM
sujitroy's Avatar
Thanks for the photo. But I can't easily see the end of the rubber pipe where it goes in to the metal line. Do I need to remove something to get access to it?
Sujit
Old Dec 8, 2021 | 10:53 AM
Ryanthegreat1's Avatar
The rubber lines are permanently crimped to the metal line. The whole assembly gets replaced. Believe it requires dropping the rear of the front sub frame several inches to gain access.
eklypze
Honda Civic (2001 - 2005)
Jun 12, 2015 10:00 AM
return_2020
May 25, 2005 01:06 PM
Hockey27925
Mar 25, 2005 10:38 AM
SupaTeg
Aug 8, 2003 03:37 PM
1.8EG-T
Aug 8, 2002 11:28 PM
