CKP code is being thrown and idk why
Old Sep 18, 2021 | 04:29 PM
Awesomemutt555's Avatar
Default CKP code is being thrown and idk why
I have a 1995 Honda civic DX with a 1.5 non VTech. It's throwing the crank position sensor code. Idk why because it has a new distributor and a new ecu. Is it possibly the wiring between the ecu and the distributor?
Old Sep 18, 2021 | 10:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: CKP code is being thrown and idk why
Very possible.
Old Sep 19, 2021 | 06:34 AM
Originally Posted by JRCivic1
Very possible.
Okay thank you
Old Sep 19, 2021 | 03:02 PM
Very possible.
So I checked the wiring between the ecu and distributor and its good. So what else could it possibly be?
Old Sep 19, 2021 | 09:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Try another distributor... and don't use one of the junk NEW ones you get from EBay, Amazon or your local Auto Parts Store. Try a known good FACTORY one from another Civic.
Old Sep 20, 2021 | 08:14 AM
Okay
Old Sep 20, 2021 | 02:31 PM
Do you know what could cause it to go bad?
Old Sep 20, 2021 | 08:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It is 27 years old and has gotten really hot about 50,000 times. If what you have is a cheap aftermarket one... consider yourself lucky if it worked more than a month. I have seen MANY of them bad right out of the box.
Old Sep 20, 2021 | 08:05 PM
True but the one I got is 250usd brand new and worked fine then the speed sensor had some problems and then I had a bad lockup solenoid and stuff so maybe that caused it so I think imma buy a cheap one off of Amazon and see if that does the trick
Old Sep 20, 2021 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
None of those issues have anything to do with the distributor... nor would they affect the distributor and cause it to fail. Again, these are all failures because the parts are OLD. Once replaced with new OEM parts, you can be confident that you won't see problems out of these same parts for many years to come.
Old Sep 20, 2021 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I am not suggesting that $250 is a small chunk of change, but just to keep your purchase in perspective... a Genuine OE Honda Distributor would have cost more than THREE TIMES THAT when you could purchase one complete... now you have to piece one together and you would still be short a coil wire... and it would still cost you almost $700.00.
scottso990
10
Aug 2, 2010 12:54 PM
ilikejesus
Jul 2, 2007 06:10 PM
Doodson
Aug 1, 2006 09:59 PM
GuyInASpeedo
Sep 25, 2003 07:05 PM
Spade
Jul 30, 2002 02:05 PM
