Grinding and loose brake pad sounding right front 06 accord
Whats up fellas man do I need some help. My 06 accord MT-6 with 153,000 , on original clutch btw, I had a grinding slash loose brake pad sound coming from my right front wheel. Thought it was sticking caliper so replaced rotor pads and caliper. While on jack stands I turned engine on and let wheels rotate and no sound at all it was good. Thinking it was good the minute I started rolling out of garage all sounds were still there. It almost sounds like dust shield grind but that is definitely clear. Tested master and it seems good. Now sound kinda changes with breaking but not completely. It’s rotational for sure and almost sounds like rotor warped but it’s brand new. It also sounds like a loose metal ring is just hanging on the drive shaft or like a loose brake pad fluttering in the caliper. I need some help before I just start throwing parts at thing. It’s kind of a rotational squeak and squeal and changes sounds as I drive and has some change when turning back and forth. Checked bearing and it’s fairly new and good. It’s definitely effecting brakes as my old pads were cracked from heat. Is it possible my brake hose is collapsed. Thank fellas in advance I love this sight.
khamoshie
Dec 20, 2010 06:10 PM
